spc rear camber kit bolts?
hey guys i just purchased a used spc rear camber kit but it did not come with the toe bolts. can the stock ones be used or do i need to purchase the spc ones? please help thanks!!
If you are wondering if you can re-use (leave) in the OEM toe bolts, then yes, but you will NOT have any adjustment for the toe...
^ You will still have toe adjustment, but the spc bolt allows for more adjustment than the oem bolt, which is usually needed after lowering. The Suspension 101 Thread will tell you all about it with big ole' pictures
great that's exactly what i wanted to know! i have toe arms to adjust the toe so dont need any more adjustments with the toe bolt, as long as the stock toe bolt works then that's perfect.
as for sdZ33- yes i purchased a used rear kit but it didnt come with the toe bolts so the question was can i use my stock toe bolts or do i have to use spc ones?
thanks again guys this answered my question!
if you have toe arms then you should look into lock out washers then. the eggcentric washers tend to move over time. lock out washers will eliminate that problem
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
