KW v2 Shock Adjustment Concern
Old Feb 17, 2012 | 02:31 PM
mike_d's Avatar
mike_d
Default KW v2 Shock Adjustment Concern
I purchased a new set of KW v2 coilovers and unboxed them last night. I wanted to check to make sure everything was included. I was interested in seeing how to adjust the rebound on the shocks. I used the provided allen key and 3 out of the 4 shocks adjusted as I expected. Little force required to adjust and I could easily feel it "click" into each position.
However, one of the shocks was difficult to adjust. It required more force and I could not feel it "click" into each position when adjusting it. I talked to KW tech support and tired to describe the problem. They just said to ship it back and they can check it out.
I didn't know if anyone else has run into this sort of problem or if I am just over concerned. This is the first set of coilovers I have owned so pardon my ignorance.
Thanks.
Old Feb 21, 2012 | 08:25 AM
ModBargains.com's Avatar
ModBargains.com
Vendor - Former Vendor
Hopefully KW can fix it asap for you - let us know how it turns out.
-Frank
Old Feb 21, 2012 | 09:40 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I have the KW V2 and none of mine are hard to adjust. They turn real easily without any resistance and there are "notches" you can feel at each 1/6 turn.
Old Feb 21, 2012 | 10:27 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Definitely sounds like something is up with the adjuster on that 4th damper. I'm sure KW will take care of you.
Old Feb 22, 2012 | 02:42 AM
mike_d's Avatar
mike_d
@3hree5ive0ero Thanks for the insight.
I ended up getting an RMA number and will be shipping the shock back to KW today. I'll post an update when I get the shock back.
Old Feb 22, 2012 | 01:05 PM
Gsedan35's Avatar
Gsedan35
Sometimes the nicer a damper in constructed on the inside, does mean they have more sensitive and delicate adjustment mechanisms. Small price we pay for better stuff. Never use a heavy hand. And if something doesn't feel right, go with your senses and have the manufactuer look at them or one of their authorized agents.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Paul.
Oct 16, 2015 07:34 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Mattg350z
Oct 2, 2015 06:51 AM
