BC Racing coilover damper settings suggestions.
Ok so I just installed my BC Racing Br Series Coilovers 2 days ago.
I left them on a settings that were on straight from the box and just got them on the car so I could start to wear them in a little. Since I'm on my winter wheels and tires, I had to raise the rears a little (just the struts, not the springs [OEM type coils]) because they were set too low from when I first put them on. After 2 days of driving on them, I realized they are set a little to "bouncy" for lack of a better word.
I only use my car for daily driving, so I don't want to hear it about getting better coilovers. These were in my budget and so far other than being a little too bouncy, I have no complaints.
I wanted to know what other members with these coils are running in terms of damper settings. I'm guessing I need to go stiffer, but I don't know how much stiffer I should go. I read somewhere that you should leave them at a softer setting at first to break them in before going too stiff.
Any suggestions/info would be appreciated. Thanks.
I'm trying to avoid this from happening again, It wasn't a fun experience.
Any way to resolve this issue by adjusting settings?
This has happened to me once so far, traveling on a main road and honestly had me saying WTF. My slip light came on over a sloped bump in the road.
my rears are set to hard 8 clicks and my rear tire will come off the ground sometimes pulling in my driveway. I really need to pull my fenders in the rear and i thought that would help a little from rubbing but its still bad lol
Did you find out how you made the "bouncy-ness" less or better?
This is also my daily driver and other than that, I have no complains.
Thanks.
I don't have them yet....I'm on the fence about getting the BC Racing or waiting to save more money for the KW variant 2. My friend has the BC's on his Z and though he's never push the car while I was in it the car feels planted in a firm way. I don't track my car but I'm wondering if I should go for the KW's. If I'm correct you sound like your dissatisfied with the BC's. Just want a good handling street car.
Thanks for the reply.
I have a set of bcs on my 04 touring model when I first installed I also had a lot of bounce and was just about ready to go back to stock suspension it was that bad... I find that setting it 20 clicks from full soft and also tightening the spring damper upwards about an inch, so that the spring that sits in the basket is raised up higher to the frame of the car was the true savior it now rides wonderfully just as smooth as my stance super sports on my s14
I've got mine set to 10/8 (clicks from full soft front/rear) - best I've tried yet, but I haven't messed with it all that much. I like it better than 12/12 which I had been using per Terra's suggestion, only because there are such shitty roads here - feels better on bumps, yet seems about as tight as it was.
