Top Speed coilovers?
Old May 2, 2012 | 07:40 PM
  #41
Josh|Swag's Avatar
Josh|Swag
Originally Posted by TheWan
It really depends on what you are looking for from a coilovers... If you just want a coilover to lower your car, or "Slam" it, these will probably be an "AMAZING" coilover for the value... But if you're looking for coilovers that will improve handling and characteristic of your vehicle (which is what I want..) you should probably purchase a coilover that was purpose built with research and development behind it...
You're beating a dead horse.
Old May 3, 2012 | 09:58 AM
  #42
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Originally Posted by Rowlett
^^^TRUE
my ride is set to stiff, and I would expect more, maybe the spring perch needs more tightening.. idk
Please don't pre-load your spring.
Old May 3, 2012 | 12:40 PM
  #43
ronn1's Avatar
ronn1
^^^TRUE
Rears are 7K.
Old May 3, 2012 | 02:46 PM
  #44
Rowlett's Avatar
Rowlett
What dose this do?
More bounce?
Old Nov 13, 2013 | 04:14 PM
  #45
ElmertheGreat39's Avatar
ElmertheGreat39
Default GOOD
Originally Posted by regina350
are these coil-overs any good if anyone knows. thanks!
These coilovers are good a bang for your buck they ride real low and feel good driving nothing different from the stock suspension.Can be bouncy or you can ride stiff you can adjust to how slam you want it my touches the floor but raised fast to much scraping installing was easy straight forward you must buy a nut that holds the toe arm with the strut collom because it doesn't have them welded on like the 350z stock suspension(2 rear struts only)cost was about 25 cents at Home Depot for the to nuts.make sher to have your pre load set and all heights set once installing because it's a B$?/H to re adjust height after bring to a local shop and get a alignment cost 60$
Old Nov 13, 2013 | 04:26 PM
  #46
pyshin's Avatar
pyshin
Jesus.
Old Nov 13, 2013 | 05:28 PM
  #47
RUNWDVL's Avatar
RUNWDVL
Just...die...already.
350Z_Al
Oct 29, 2020 07:44 PM
Depravity
Oct 1, 2015 04:49 PM
