Top Speed Pro-1 Coilovers Review
Old May 3, 2012 | 03:44 AM
  #61
Rowlett's Avatar
Rowlett
Originally Posted by K-SWIZZ
That looks pretty Low to me. Nice almost perfect height.
Couple questions:
How long have you had them on your car? And if you can post up your overall Review of them. Would be helpful.
Iv only had them on for 2 weeks now
Review:
https://my350z.com/forum/brakes-and-...-purchase.html
Old May 3, 2012 | 11:31 AM
  #62
ronn1's Avatar
ronn1
Another review comming soon here:
http://www.zcarmotoring.com/showthre...-Street-Series
Old May 3, 2012 | 08:25 PM
  #63
K-SWIZZ's Avatar
K-SWIZZ
Originally Posted by ronn1
Nice, That's my review actually. I still haven't got a chance to put them in.
Old May 4, 2012 | 08:01 PM
  #64
1991ls13's Avatar
1991ls13
Update on my review....My front are just stupid noisy....Thought it was maybe my lug nuts were loose or something with the suspension....So i went back in and tightened everything down but its still there....The poping and `loose metal` sound....IDK what it is but I`m starting to worry
Old May 4, 2012 | 08:41 PM
  #65
Rowlett's Avatar
Rowlett
This may sound dumb but I actually left the front damper nuts (3 on top) on and installed, then realized and noticed that the struts came with nuts..
check from under hood if you didnt remove already, you will see a larger gap inbetween
funny I tought it was part of assembly..
Old May 4, 2012 | 08:55 PM
  #66
ronn1's Avatar
ronn1
That would definitely be a problem...
BTW, clunking sounds are usually the upper strut mounts.
Old May 12, 2012 | 07:07 AM
  #67
Rowlett's Avatar
Rowlett
So what was the problem, everything work out??
Just curious..
Old May 13, 2012 | 12:27 PM
  #68
block8head's Avatar
block8head
What is the preload for the rear springs?
Old May 13, 2012 | 06:31 PM
  #69
block8head's Avatar
block8head
I have the same fricking noise in the front and now make me wonder if all coilovers are like that?
I did removed those nuts btw...
Old May 14, 2012 | 03:53 PM
  #70
djwatts's Avatar
djwatts
Any more reviews? Seems like the thread to purchase these have stopped. These seems too good to be true.
Old May 26, 2012 | 12:37 AM
  #71
1991ls13's Avatar
1991ls13
no i still have the poping - loose noise. I went back in and couldnt find anything loose so Im lost.....
Old May 26, 2012 | 10:59 AM
  #72
ronn1's Avatar
ronn1
Sounds like classic upper strut mount being loose or worn out. Double check.
Old May 26, 2012 | 06:22 PM
  #73
Darkknight916's Avatar
Darkknight916
is the noise the shock piston hitting the hood
i had that problem with my DA integra, it was slammed, and back in the mid 90's, things weren't as available as they are today, so i made it the best i could. turned out the koni piston was bangin on the underside of the hood because i had it lowered so far and couldn't adjust the preload or dampening.
ALSO:
Has anyone set their car up with the "True" coilover setup for the rear? I just did mine today, and it seems cheesy. I don't think it's correct but i put the coil spring on the actual shock body without any extra perch. If i used the perch, the bolts for the top shock mount would have hit it and not allowed the spring to sit level. So, i just used the spring and the spanner nuts (all three). The third spanner nut was used to keep the threaded body of the shock tight with the mounting point of the knuckle.
it's a lil scary thinking that the way i set them up is the way they are "Supposed" to be set up.
hope this helps
Old May 26, 2012 | 10:00 PM
  #74
1991ls13's Avatar
1991ls13
i did mine true style. Rear is just fine on mine, its just the fronts.
Old May 27, 2012 | 12:59 PM
  #75
Darkknight916
you have any pics of the rear coil setup?
Old May 27, 2012 | 04:56 PM
  #76
block8head's Avatar
block8head
+1 on pics
Old May 27, 2012 | 06:02 PM
  #77
ALO8's Avatar
ALO8
Old May 27, 2012 | 06:55 PM
  #78
1991ls13's Avatar
1991ls13
I work all week, but ill try and get a pic
Old Jun 1, 2012 | 05:17 PM
  #79
Darkknight916
it's friday... remember those pics of the rear? :-)
i'll have to see if i can't get a decent shot of the way i set the rears... (which i think is a $#it design)
Old Jun 1, 2012 | 08:28 PM
  #80
1991ls13's Avatar
1991ls13
^ ok fine tomorrow morning i`ll try and get a pic. honestly there are pics already up of what the true coils look like. just an empty bucket `ugly` as hell.
