Stoptech Big brake Fronts review
Old Apr 7, 2012 | 06:36 PM
ronn1's Avatar
ronn1
Default Stoptech Big brake Fronts review
Just installed Stoptech fronts only..13" with 4 pot calipers on my 08.
First off...it's gonna be hard to improve on the STOCK set up for 08s, since they really have more than adequate braking. In fact..put on the right pads and you can take em to the track.
I wanted to kick it up a notch, so I went for the Stops 13" upgrade. These are really designed to retain the stock rears..I like that. I matched the rear pads though (Stoptech Street Performance pads). All I can say is NICE! The brake bias is perfect...this allows you to modulate braking without activating the ABS 99% of the time. Very predictable braking...linear response. Zero fade on 20 consecutive 80-20 pull downs. Pedal is ROCK hard.
Most of all..they look fuggin' fantastic
Oh..here's a snipet from long ago..right on the money...
https://my350z.com/forum/2169173-post34.html
What are your goals and constraints? Are you looking for aesthetics and will only consider a 4-wheel kit? Or are you just looking for the biggest bang for the buck improvement in pedal feel at the lowest possible cost? If it's the latter, then I would suggest the 13" front only kit. That gets you 90 percent of the improvement in brake feel and pedal firmness at a lower cost
Old Apr 8, 2012 | 07:31 AM
R350Zz33's Avatar
R350Zz33
Pix or it dident happen
Old Apr 8, 2012 | 11:42 AM
ronn1's Avatar
ronn1
I thought if ya seen one ..ya seen em all..
but I'll go ahead and post one later today.
Old Apr 8, 2012 | 01:03 PM
R350Zz33's Avatar
R350Zz33
I have I just want proof lol
Old Apr 9, 2012 | 03:29 PM
ronn1's Avatar
ronn1
Pics for ya:
Stoptech 332mm 4 pots front only.
..picked these up BRAND NEW for $1430 shipped
BTW..I have 18X9.5 F (+26) and 18X11 rear (+28 with 5mm spacer=+23).
Old Jul 19, 2012 | 07:11 AM
VroomVroom's Avatar
VroomVroom
Where did you get them brand new for only $1430? That's quite cheap from what I've seen. I am strongly considering front & rear Stoptech BBKs for my '04 base Z. The stock brakes (not Brembo) aren't cutting it at the track.
Old Jul 19, 2012 | 09:21 AM
Voboy's Avatar
Voboy
^- +1. Wicked cheap.
Old Jul 19, 2012 | 12:40 PM
BoomerZ33's Avatar
BoomerZ33
^^ ridiculously stupid cheap
Old Jul 19, 2012 | 02:47 PM
SE5spd's Avatar
SE5spd
If I found ST BBK for $1400 new I'd pick it up too. lol.
07ZEKE
Aug 23, 2021 09:15 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
