Alignment Question
Old Jun 17, 2012 | 04:01 PM
Dubs13's Avatar
Dubs13
Default Alignment Question
I noticed that there are lockout washers out there for the Z. I was wondering if it's something I should buy for the camber arm bolts or if the eccentric washers are necessary? Cause the way I understand it, the camber arm is to adjust camber and the toe bolt at the spring bucket is to adjust toe, however you can adjust toe at the camber arm and camber at the toe bolt. What is the proper procedure to align the car so I can tell the tech, and should I buy the lockout washers for the camber arm?
Old Jun 17, 2012 | 04:41 PM
SE5spd's Avatar
SE5spd
Buy them.
Old Jun 17, 2012 | 04:52 PM
-Trav-'s Avatar
-Trav-
Get lockout washers for the arms, since youll be adjusting camber on the arm from now on. If you ever have a need for a toe arm in the future youll want a lockout for those too.
Just let the tech know what you have installed and theyll figure out the rest.
Old Jun 17, 2012 | 04:58 PM
-Trav-'s Avatar
-Trav-
Now how is that possible??
Old Jun 17, 2012 | 06:49 PM
terrasmak's Avatar
You don't actually adjust from the other position, but camber changes with toe, toe changes with camber
Old Jun 17, 2012 | 07:09 PM
-Trav-'s Avatar
-Trav-
The way he worded it made it sound as if he was dialing in camber setting through the toe bolt and vice versa, hence the call-out. The way you worded it is clear.
Old Jun 18, 2012 | 05:25 AM
Dubs13's Avatar
Dubs13
Are they necessary even if I'm not tracking the car? Are the washers notorious for slipping or should I be ok without the lockout washers?
Old Jun 18, 2012 | 06:48 AM
JasonZ-YA's Avatar
JasonZ-YA
The issue is this:
POST 19 from suspension 101 thread:
https://my350z.com/forum/8293599-post19.html
-J
Old Jun 18, 2012 | 10:14 AM
-Trav-'s Avatar
-Trav-
Its cheap and easy so you might as well just do it. Refer to Jasons post above for more detailed info.
issyz
Jul 2, 2017 03:04 PM
Depravity
Oct 1, 2015 04:49 PM
