Energy Suspension Poly FTMFL
Old 08-06-2012, 01:09 AM
  #41
silvertouringz
silvertouringz's Avatar
Originally Posted by djamps
2 months and 2000 street miles we have this wonderful compression rod bushing which apparently decided to split:
To add to that, only two weeks of normal street use and one track day, my ES rear diff bushing tore down the middle and ejected itself out the rear onto the track. It also damaged the bolt on my diff cover.
So I'm 0/2 for ES poly bushings + collateral damage... not a happy camper.
I assume you are lowered? how much?
Old 08-06-2012, 01:50 PM
  #42
djamps
djamps's Avatar
Barely lowered. H techs.
Old 08-06-2012, 06:03 PM
  #43
freddys 350z
freddys 350z's Avatar
just a close up of the whitelines i got today. look beefy with a well thought out design.
[URL="[ame=http://www.flickr.com/photos/72945596@N08/7729964106/][/ame]
[ame=http://www.flickr.com/photos/72945596@N08/7729964106/]photo 3[/ame] by [ame=http://www.flickr.com/people/72945596@N08/]freddy 350z[/ame], on Flickr"]http://www.flickr.com/photos/72945596@N08/7729964106/http://www.flickr.com/photos/72945596@N08/7729964106/ by http://www.flickr.com/people/72945596@N08/, on Flickr[/ame]
Old 08-07-2012, 06:26 AM
  #44
djamps
djamps's Avatar
Where did you get those? And yes they look far better.
Old 08-07-2012, 02:33 PM
  #45
freddys 350z
a seller on ebay.
Old 08-07-2012, 03:14 PM
  #46
JaE35z
JaE35z's Avatar
interesting...my ES rods are holding up fine
Old 08-07-2012, 03:15 PM
  #47
JaE35z
JaE35z's Avatar
http://www.ebay.com/itm/Whiteline-Pl...r#ht_500wt_793
Old 08-08-2012, 06:25 AM
  #48
JasonZ-YA
JasonZ-YA's Avatar
photo 3 by freddy 350z, on Flickr
Yes, much better design consideration! They understand the fact that the compression arm has to articulate...duh Energy suspension!!
-J
Old 08-08-2012, 09:42 PM
  #49
go kart
go kart's Avatar
i can see where the whiteline design is better but i thought id chime in. my energy compression bushings have 11k on them and theyre still great. been lowered roughly 1.25" the whole time.
Old 08-09-2012, 08:13 AM
  #50
djamps
djamps's Avatar
Thanks man. I have some stock bushings laying here but don't feel like having to remove the rod and press them in. Going to give the whitelines a shot -- just ordered a set.
Old 08-09-2012, 08:16 AM
  #51
djamps
djamps's Avatar
Actually, being lowered will make them last LONGER. Notice how squished mine look, that is when the suspension is fully articulated. The lower the suspension sits and the less it articulates, the less likely they will be damaged. I think my near stock height and front end lifting at the 1/4 track is what did them in quickly.
Old 08-09-2012, 01:38 PM
  #52
AllstarE4
Sleeps in 350Z
AllstarE4's Avatar
I thought it was the exact opposite. The lower the car the more stress you put on the compression rod bushing.
Old 08-09-2012, 03:42 PM
  #53
djamps
djamps's Avatar
You're correct with regard to the stock bushings. But for the poorly designed ES bushings it actually works in your favor.
Old 08-10-2012, 07:39 PM
  #54
freddys 350z
this bushing is kicking my ***. since it does not articulate like the spl, its impossible to line it up with out taking apart most of the suspension. you have to jack up the spindle to try and line up the ball joint. i think i got a game plan for it and will probably post a diy on it sine it different then the spl.
Old 08-13-2012, 07:57 AM
  #55
djamps
djamps's Avatar
You'll have the same 'issue' with OEM or any other kind of rubber bushing -- yell at nissan about it LOL. SPL is a special case.
Old 08-13-2012, 09:25 AM
  #56
freddys 350z
i got a process figured out. i can get each side on in 10 min now.
Old 08-27-2012, 10:27 AM
  #57
djamps
djamps's Avatar
Pretty sure my diff isn't going to give me any more issues. Also got the whiteline compression bushings in the front.
Old 08-27-2012, 10:51 AM
  #58
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
Is this what you got OP?
http://www.ebay.com/itm/Whiteline-Pl...#ht_500wt_1180
Old 08-27-2012, 12:14 PM
  #59
djamps
djamps's Avatar
Nope, I am using solid mounts for the diff:
http://www.forgedperformance.com/sto...roductid=19668
An this brace:
http://www.spracingonline.com/store/...ial_Brace/3713
Here is what I am now using on the front compression rods:
http://www.ebay.com/itm/Whiteline-Pl...2f2fd3&vxp=mtr
Old 11-20-2012, 04:27 PM
  #60
steidz
steidz's Avatar
So were does the articulation of the compression rod go? does the whole bushing flex around the center bearing or is it still just the "ears" of the bushing flexing with the arm movement.
Quick Reply: Energy Suspension Poly FTMFL
