Fortune auto coilovers...messed up my order and sent me extra parts.
Old Sep 15, 2012 | 09:52 PM
  #61
User 42426's Avatar
User 42426
^^wat spring rates on your oem setup?
Old Sep 16, 2012 | 09:50 AM
  #62
freddys 350z's Avatar
freddys 350z
mine are 10k/8k and i believe his are 8k/8k
Old Sep 16, 2012 | 04:33 PM
  #63
Z_on_TE37's's Avatar
Z_on_TE37's
9k 8k
Old Sep 16, 2012 | 04:35 PM
  #64
Z_on_TE37's
Hey freddy, does your spring adjuster on your rear passenger side need to be lower than the drivers side to get them level ?
Old Sep 16, 2012 | 04:40 PM
  #65
freddys 350z
no. i would check your upper and lower springs mounts to make sure they are set the same.
Old Sep 16, 2012 | 06:54 PM
  #66
Z_on_TE37's
I did. I tried a bunch of stuff, nothing works. I honestly think my springs are different
Old Sep 16, 2012 | 07:21 PM
  #67
freddys 350z
according to fortune, they only make one kind of rear springs. are your shocks set the same?
Old Sep 16, 2012 | 07:26 PM
  #68
terrasmak's Avatar
Very typical on a Z , even with specific rate Swift coils mine are adjusted different. Also the sway bar can cause some problems without adjustable endlinks.
Old Sep 16, 2012 | 07:46 PM
  #69
Z_on_TE37's
Yes my shocks are set the same. I have them both maxed out on low. The passenger side coil is set on maxed out low, my drivers side is about 3/8" from all the way low, and its still lower than the passenger side. It really pissed me off bc they should theoretically be the same if both sides are set the same. I'm really disappointed on this one, I'm calling fortune tomorrow, maybe they'll come up with a solution. If not, I'm gonna switch the components to the opposite sides and see what it does.
Old Sep 16, 2012 | 07:48 PM
  #70
Z_on_TE37's
Dude, I wish I knew as much as you with the Z suspension. I really need some advice here, please help me out
Old Sep 16, 2012 | 09:46 PM
  #71
terrasmak's Avatar
First , buy some quality coilovers
Second, fill the gas tank, make all adjustments on a full tank
Third, make sure your surface is level
Fourth, disco sway bars ( one endlinks per bar is all that's needed)
Fifth, if you have OEM bushings, slightly loosen them ( they cause a bind , and the bind can be uneven )
Sixth, make you adjustments
Seven, tighten your bushings back up
Eighth, set preload on sways to Zero when you reconnect them.
Ninth, get car aligned.
Step 6 I also like to set the shock travel/shock length before preload. No point of having a bunch of unusable travel. If you do that you will maximize bump and extension travel. Then I set ride height with only preload.
Old Sep 16, 2012 | 11:10 PM
  #72
freddys 350z
the quality of the coilover is irrelevant to setting them even. as you said, even your high end coilovers are uneven(even though im unsure what you have). so much for number one. every thing else i agree with.
z on te37. ulsess your setting this thing up to race, just adjust the coilovers till its even. assuming you have stock bushings and sways, links.
if it were mine though i would take the time and do it. also try what you were saying about switching springs.
Old Sep 17, 2012 | 10:15 AM
  #73
terrasmak's Avatar
Qualty coilovers are always a good thing, but YES you will have a problem with any coilovers. Even the drop spring crowd has this problem.
BTW typically on a car that has been on the corner scales and properly corner weighted, the pass side sits about 1/8 inch high. I just set the pass side 1/8th inch high now when i set the suspension up now.
Swapping springs will do nothing, unless you have a weak spring. If you have a weak spring, and its on the proper side, you car will be level.
Most of the time i find the front sway bar and height setting are what screw up the rear. Minor adjustment up front will change the rear height a lot.
Old Sep 17, 2012 | 10:31 AM
  #74
Z_on_TE37's
Well this is what I'm gonna do, first, I'm gonna check all of my settings up front. Then ill loosen and retighten my rears to make sure there aren't any bushings working against me. Next, ill put a little over a half a tank of gas in. After all of this, ill see how it levels out, if its still off, I'm gonna switch the sides that the springs are on and see if one is weak, if so, fortune auto is never gonna hear the end of it.They stress how evenly balanced their shocks and springs are.
Old Sep 17, 2012 | 10:49 AM
  #75
terrasmak's Avatar
Shocks have nothing to do with the height, only springs.
OEM style bushings act as a spring
Sway bar acts as a spring
Springs acts as a spring.
BTW the reason for a full tank of gas is to make sure both sides of the tank have equal amounts of fuel. We have a saddle tank that is not even close to beimng a perfect design.
Old Sep 17, 2012 | 11:08 AM
  #76
03threefiftyz's Avatar
03threefiftyz
Also, tire sidewall is a spring...
Old Sep 17, 2012 | 11:11 AM
  #77
KingBaby's Avatar
KingBaby
Hardest Setting
a slippery one.....
Good info...I thought this was a bash the junk coil thread!
Old Sep 17, 2012 | 01:24 PM
  #78
Z_on_TE37's
Originally Posted by KingBaby
a slippery one.....
Hey, woah. At least I bought average coils, I coulda been a cheap *** and bought real junky ones or lowering springs, I'm a college kid with an average job, cut me some slack.
Old Sep 17, 2012 | 01:52 PM
  #79
terrasmak's Avatar
Nothing wrong with lowering springs, most with a proper set of dampers will be better than cheap coilovers.
Old Sep 17, 2012 | 02:03 PM
  #80
KingBaby's Avatar
KingBaby
Hardest Setting
no jab at you man....I'm on junk coils also supposely
