BC Racing BR Coilovers need HELP!!
Old Sep 26, 2012 | 01:01 PM
sidewayz_Z33's Avatar
sidewayz_Z33
Default BC Racing BR Coilovers need HELP!!
I recently bought some bc racing br type coilovers used. I want to reset the preload and i saw bc racings video on preload setting, but the problem im having is i cant loosen the lower spring seat. I can get the locking ring loose but i cant get the lower spring seat. I even sprayed wd40 in between the threads and still nothing. Any advice would be helpful, thanks.
Old Sep 26, 2012 | 04:27 PM
sportbiketed's Avatar
sportbiketed
Try soaking it in pb blaster for a few hours
Old Sep 26, 2012 | 04:48 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
PB Blaster, possibly a hammer and a screwdriver.
Once you've broken it loose, clean the threads and be sure to apply lots of anti-seize.
Old Sep 26, 2012 | 05:22 PM
KingBaby's Avatar
KingBaby
Hardest Setting
+1
rubber hammer
Old Sep 26, 2012 | 06:52 PM
sidewayz_Z33
Thanks for the advice. I ended up soaking the threads with wd40 5 time with 30 minutes in between each soak. After the 5th time the spring seat gave in. Man was that a relief. Again thanks for the help.
Old Sep 27, 2012 | 09:02 AM
VMRWheels's Avatar
VMRWheels
Like I said, be sure to use anti-seize now!
Old Sep 27, 2012 | 10:32 AM
Bmurray350z's Avatar
Bmurray350z
for future reference, use pb blaster instead of wd-40.
Old Sep 27, 2012 | 12:28 PM
sportbiketed
^This WD40 is a water displacing spray, not a penetrating catalyst like PB Blaster.
Old Sep 27, 2012 | 02:22 PM
sidewayz_Z33
yes i will be using anti-seize when i put them on
Old Sep 27, 2012 | 02:24 PM
sidewayz_Z33
I only had wd40 so i thought i would give it a try and it worked but if this ever happens to me again ill be using pb blaster to make my life easier
EnjukuRacing
Sep 30, 2015 06:55 AM
