Holy metal fatigue, Batman!
Old Nov 18, 2012 | 04:39 PM
N80's Avatar
N80
Default Holy metal fatigue, Batman!
I noticed these cracks in my right front steering knuckle when I was changing my brake pads/rotors. The red arrows show the extent of the cracks that don't show up well in the photo. None of these cracks extend around the corners of the steering knuckle so I don't know if they are just surface cracks or something more serious.
The steering knuckle looks like it has some sort of surface treatment, paint maybe (?), so I'm hoping these cracks are only surface.
Opinions?
Old Nov 18, 2012 | 07:06 PM
Russ@Z1's Avatar
Russ@Z1
Looks like surface from that picture.
Old Nov 18, 2012 | 07:48 PM
terrasmak's Avatar
Forged part, i believe mine looks the same. I have also bent one too, adds camber when you bend the upper area, great for CS autocross and Spec Z
Old Nov 18, 2012 | 07:59 PM
Gunsmoke's Avatar
Gunsmoke
Really looks more like a surface defect probably due from the cracking in the die it was cast in. The dies usually develop cracks like that over time and it will show in the casting. The die is obviously in its later stages of use because to the right of the hole you can see weld marks where it has been repaired.
The coating you are referring to is probably the release agent they used on the die.
I worked in aluminum casting industry for years as a Quality Engineer and thats a typical die cast part and surface appearance
Below is example of die thermal cracks - they can either make a recessed looking crack or a protruding flash line depending on the flow characteristics of the die.
Probably since that is a hot spot in the die some material is pulled out when it separates, mirroring the die crack into the casting. you can see some other places on the part that had some pulled out as well. Also looks like a heavy flash line on the edges indicating that die was probably nearing a service. Heavier die release also is a good indicator of that, explaining the excessive staining you refer to as "surface treatment or paint".
In other words, it looks fine, if you want to see if its really a crack, mag particle or dye penetrant is the only real nondestructive way to do it.
But again, I dont think its a crack.
Last edited by Gunsmoke; Nov 18, 2012 at 08:09 PM. Reason: better explained myself
Old Nov 18, 2012 | 08:18 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
no worries there man its just surface
Old Nov 18, 2012 | 09:12 PM
ronn1's Avatar
ronn1
Opinions?
Surface
Old Nov 19, 2012 | 04:08 AM
N80's Avatar
N80
Thanks guys.
Old Nov 19, 2012 | 08:49 AM
ian99rt's Avatar
ian99rt
The inside surface of my nismo diff cover looked 1000x worse. All surface cracks.
Old Nov 19, 2012 | 10:44 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Definitely looks like surface cracks!
etkms
Jun 19, 2022 06:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
JmanZ
Aug 29, 2002 08:31 PM
