sway bar smashing oil pan issue..advice please
Old Jan 16, 2013 | 07:11 PM
zach711f's Avatar
zach711f
U might be right. But I was at the samemridemheight with my stock arms and I had the sway bars on the most stiff settings with out an issue. Now that I put the Pbm kit on I have this problem here's a pic of current ride height
Old Jan 16, 2013 | 08:16 PM
Voboy's Avatar
Voboy
royal_t installed the endlinks the other way...then again i dont think its been running yet
https://my350z.com/forum/9933530-post506.html
Old Jan 16, 2013 | 08:27 PM
zach711f's Avatar
zach711f
Hmm weird. I don't think it should make a problem installing them either way. Looks like his big oil pan in right against the sway bar as well. Hope he doesn't run into the same problem. My oil pan was ****ed and my sway bar endlinks bent in half and my sway bar bent a little where the colar of the sway bar mounts to the frame.
Old Jan 17, 2013 | 02:48 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
like it was said before. That mounting point is too high. Looks like the PBM control arms are not meant to be used on a slammed car. How are you going to use the extra steering angle while slammed anyway?
You are at the extent of the geometry. The only fix is to either cut/weld or to raise the car up considerably.
I still do not like the angle of your end links. Royal-t's look much better.
Old Jan 17, 2013 | 02:56 AM
zach711f's Avatar
zach711f
I can achieve full lock with no rubbing issues at my current ride height. I'm def not going to be cutting and welding my Pbm kit or cabbing my sway bar. Looks like I will be raising the car like a lifted Chevy today hahah. I'd rather have function over looks. Also according to Pbm install pics royal t installed his endlinks wrong.
Old Jan 17, 2013 | 08:10 PM
zach711f's Avatar
zach711f
Raised the car .25" and it didn't do shyit..I'm going to have to lift it up like a monster truck...
Old Jan 17, 2013 | 08:34 PM
terrasmak's Avatar
You need to start with setting the shock length, make sure it hits the bump stops before your sway hits the pan.
Old Jan 17, 2013 | 09:08 PM
zach711f's Avatar
zach711f
[QUOTE=terrasmak;10014785]You need to start with setting the shock length, make sure it hits the bump stops before your sway hits the pan.
I took off the control arm. Then I spun down the Coilover mounting deal .25". Spun down the lock ring. Is that what ur talking about for shock length?
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
