Rear bushing question
Old Apr 14, 2013 | 12:03 PM
Kipper_15's Avatar
Kipper_15
Default Rear bushing question
Are the rear bushings a *must have* on part?
Have been hearing different inputs saying yes and no, so would like to open this question to see what others think.
Old Apr 14, 2013 | 12:40 PM
DESRTpunk's Avatar
DESRTpunk
Yes they are. I mean, the car will run without them, and it's not vital like say a water pump or alternator. The bushing consists of an outer metal sleeve, a rubber bushing and an inner metal sleeve. Without the bushing, the metal ends of the control arm would be mounted to the frame and cause metal-to-metal contact. This would cause major clunking as the car goes over bumps on the road. It gives you a more manageable and quiet ride.
If you don't have any bushings, besides a loud and uncomfortable ride, it will also affect your handling negatively and give you poor alignment and camber. It also leads to poor tire wear and control.
Old Apr 14, 2013 | 08:29 PM
terrasmak's Avatar
What rear bushing are you talking about
Old Apr 14, 2013 | 08:41 PM
JasonZ-YA's Avatar
JasonZ-YA
^ also, for what use??? daily driving...no, autoX....sure, road racing, Yes...
form follows function...
if your rear diff bushings is blown - leaking on the subframe, then yes for any instance...etc..etc....
if you just want all the neat things then no.....
more info needed...
-J
Old Apr 15, 2013 | 08:54 AM
Kipper_15's Avatar
Kipper_15
Yeah sorry for the lack of info. It's the bushing where the bolt connects to the coil? So is that the rear lower control arm? And my Z is for daily driving.
Old Apr 15, 2013 | 09:52 AM
terrasmak's Avatar
Not needed untill they are worn out or if you want to reduce stiction on a track car. Same with the rest of the rear suspension bushings except for the shock mount on the spindle if you run a true coilover.
Old Apr 15, 2013 | 12:45 PM
Kipper_15's Avatar
Kipper_15
Ok. Which bushing is this? the one where the coil is being held by, so I know which one to buy.
Attached Thumbnails Rear bushing question-sccp_0210_08_z-2003_nissan_350z_tuning-rear_suspension.jpg
Old Apr 16, 2013 | 08:00 AM
terrasmak's Avatar
Spring mount? Draw an arrow on the pic pointing to exactly what bushings you are talking about.
Old Apr 16, 2013 | 09:58 AM
Kipper_15's Avatar
Kipper_15
There is a red arrow pointing right to it. Inside that control arm.
Old Apr 16, 2013 | 12:59 PM
thekinn's Avatar
thekinn
I guess that would be where the shock attaches to the rear axle. It looks like this bushing - see courtesyparts.com
http://www.courtesyparts.com/43052f-...8-p-15782.html
http://www.courtesyparts.com/350z-pa...5_800_803.html
Old Apr 16, 2013 | 02:34 PM
joshua350z6841's Avatar
joshua350z6841
yes its where the rear shocked attach is to the knuckle just did mine not to bad
Old Apr 16, 2013 | 04:46 PM
terrasmak's Avatar
This is the answer to your question. Whiteline, Nismo and SPL all offer them. Very simple to swap.
PLAYDIRTY
Oct 12, 2015 07:45 AM
CJs_Z33
Sep 18, 2015 12:06 PM
Suffolk350z
Sep 13, 2015 02:43 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
