removing brake rotors
I got the rotors on! The front two 22mm bolts need to be tightened to 113-114ft-lbs. The rear 19mm 110 ft-lbs.
I used an impact wrench, so easy for the front, and the rear I was able to get the torque wrench in there and brake them loose.
Hell yeah! and save the cash too. My dad suggested with the cash I saved buy one of the tools I borrowed. I think I am gonna get a nice torque wrench. Thanks for you guys help!
Looks so good too.
Looks so good too.
Congrats on getting the job done!
I have a suggestion: Do NOT use a torque wrench as a breaker bar. You'll damage it's sensitivity. Splurge on a good 18" breaker bar. Also "cheater bars" help. Find a 2 or 3 ft steel pipe that will slide over the breaker bar handle. I've lived in the rust belt most of my life, so I've needed.....help, a lot.
Mine is an old Craftsman 1/2" drive. Had it for almost 30 years. A few weeks ago I helped a friend put brakes on his BMW....needed a 5' cheater bar over the breaker bar to remove the friggin lug nuts......big time corrosion. Bars worked well, but I did break my Matco 1/2" to 3/8" socket adapter.
I busted my crfatsman 1/2-3/8 adapter as well from trying to remove my lugnuts from the 350Z after a visit to the dealer!!!!!
Good news.....I finally ran into a Matco truck parked outside a Body shop today. Not only was there no question about replacing my impact grade adapter with a New & Improved version, he broke open a new set to do it!
It took a while, but here is a link to the breaker bar:
http://www.sears.com/sr/javasr/produ...id=00944202000
Man, their site sucks!
Originally posted by J Ritt
In the rear....DO NOT FORGET TO DISENGAGE THE PARKING BRAKE if you're going to try and remove the rear. Don't ask me how I know...heh.
Sure enough my parking brake was on! I disengaged the brake and the rotor came right off no problem...LOL.
I don't know what to do without you guys! LOL
Jeff
Originally posted by Sponge
FairladyZ:
Which rotors did you get?
Can we get a review?
FairladyZ:
I can give a good review with pics tomorrow evening.
