true coilover feedback
Old Jul 23, 2013 | 10:06 AM
350zsteez's Avatar
350zsteez
Default true coilover feedback
hey guys I was wondering whose running true coils and have had problems with it short term/long term. clunking, quick leakage etc. any feedback is greatly appreciated! searched but all I found is the comparison between oem vs true. thanks in advance!
Old Jul 23, 2013 | 10:20 AM
X.et's Avatar
X.et
Have run both oem and true with no issues, I haven't ever seen anything suggesting true or oem to be superior to one another.
Old Jul 23, 2013 | 01:15 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
I've been running true coils (crap brand) on my car for a year. The only noises I get are from the not cheap parts needing maintenance.
You're not going to see a quality change from one style to another seeing as I have had both setups. Stuff like that comes mostly from the install, then the brand. Because remember even crap coils can be installed correctly and run problem free like what I've experienced.
Old Jul 23, 2013 | 02:42 PM
350zsteez's Avatar
350zsteez
thanks for the reply guys. I've just been stuck on getting either pbms which I hear really good things about or stance super sport oem style. I was really afraid of the bushings going bad. did you guys replace them or still haven't ran into an issue with them?
Old Jul 23, 2013 | 03:31 PM
stuartc323's Avatar
stuartc323
There is no difference between OEM style and True style except for spring rate differences on the rear wheel.
You will get noise from pillowball mounts, random bolts, spring perches, doesnt matter how much you pay for your coilovers.
If you buy a good set of coilovers, you wont have to worry about the shocks going out soon or blowing under extreme use.
If you can buy new, if you cant buy greatly underused.
Old Jul 23, 2013 | 03:32 PM
deens123's Avatar
deens123
I changed out most of my bushings prior to install of coilovers...but it's up to you. I think they work better then the stockies and poly is much stiffer. The compression rods, A-arms will be a good start since your going to a coilover but no rush ....if your stock bushings are good just know you may have to change out down the road.
For me it was easier to just change out the bushings since I was installing my coilovers myself and would have everything apart.
Old Jul 23, 2013 | 03:45 PM
stuartc323's Avatar
stuartc323
+1 ^
Your car will feel more crisp and on point with new bushings.
Old Jul 23, 2013 | 04:23 PM
350zsteez's Avatar
350zsteez
I'll definitely go ahead and do that just in case. any suggestions on quality bushings? and which ones I should get. I'm pretty low and expect my bushings to go a lot quicker so mine as well.
Old Jul 23, 2013 | 05:43 PM
terrasmak's Avatar
True style will wear out the shock faster, just do to tensions of the spring , bushings ect etc. Spring rate stuff, ever so slight difference caused by the pivot point , I guess it has to do with the anti squat design that gets bypassed with true coilover. If SPL was not back ordered when I did my build , I would have OEM style
Old Jul 23, 2013 | 05:52 PM
Chi-TownWarrior
This.....
If you're willing to spend the money, then do this. I plan on doing this in the near future.
Old Jul 24, 2013 | 12:14 AM
350zsteez's Avatar
350zsteez
decisions decisions. I'm more towards oem style now. seems everyone prefers those and majority says it's then all around better option
Old Jul 24, 2013 | 03:42 PM
stuartc323's Avatar
stuartc323
There are a lot of options going the OEM style route, it would be a better choice for a car that doubles as DD/weekend toy
Bushings:
Find a set of Polyurethane bushings, such as Energy Suspension or something similar
Old Jul 24, 2013 | 09:08 PM
350zsteez's Avatar
350zsteez
which bushings do you guys think I should replace? my car just hit 145k.only one I thought of was the lower control arm(transverse link) one.
Old Jul 24, 2013 | 09:54 PM
terrasmak's Avatar
Front LCA, shock mount and compression arm. Rear shock mount. Those would be my choices from experience
Old Jul 25, 2013 | 04:21 AM
350zsteez's Avatar
350zsteez
are all the bushings the same or do i buy different new for each location? sorry for noob questions
Old Jul 25, 2013 | 03:18 PM
deens123's Avatar
deens123
Post I love the ones I have
Everyone has there own opinion and mines ended up being Energy Suspension, because they can be hand pressed/C- clamped or pushed in with a shop vise. I have a cheap press I got from harbor freight, its much easier with E.S. then with other brands. They are very stiff which is a huge benefit on the track/auto cross, but still driveable unlike solid bushings.
You will have to lube them very good and every few months ( 2 times a year check to make sure they are all lube up) which some people complain about but to me .... It's part of my basic maintenance
I had many vendors try and talk me out of buying E.S. but they also make more on other brands... You have to do your research and not listen to some of these vendors .... If your gonna have someone press your bushings in then it comes down to opinion and your Wallet.. If your going do it yourself ... E.S. is a easy choice .... Good luck!
May 30, 2017 03:28 PM
Dymsi
Sep 29, 2015 11:32 AM
