Need advice on my alignment
Old Aug 7, 2013 | 08:43 AM
ChrisNelson's Avatar
ChrisNelson
Default Need advice on my alignment
Thanks for looking at this thread, I just got an alignment done and new tires on my 2005 350z Enthusiast because I upgraded some of the suspension components.
Kinitex Front/Upper Adjustable Control Arms
Kinitex Rear Camber Arm
Kinitex Rear Traction Arm
The car has stock ride height other than that, here's what the alignment ended up being:
I mostly do regular street daily driving with the car but a few times a year I get to bring it to the race track for road course and drag racing.
Does anyone have any advice on what they see in my picture?
Thanks!
Old Aug 7, 2013 | 08:50 AM
350zjason350z's Avatar
350zjason350z
Know it all
Looks like they just aligned so it was in spec ... But not exactly the same on each side...
Old Aug 7, 2013 | 08:51 AM
Neeko94's Avatar
Neeko94
advice on what???
If you want to handle better then get sway bars (go both ways actually) and coilovers.
i dont get what your trying to get advice on?
Old Aug 7, 2013 | 08:59 AM
terrasmak's Avatar
As a DD, do you run a lot of canyons and twistly backroads?
Old Aug 7, 2013 | 09:04 AM
ChrisNelson
There are no canyons around here and only a few twisty roads, but I want it to perform well when I get to the track.
Old Aug 7, 2013 | 09:06 AM
ChrisNelson
Originally Posted by Neeko94
advice on what???
Sorry for not being more clear.
1. I want to know if this is a good alignment setting for this car for both daily driving and the occasional track usage.
2. Should anything be changed to make it handle better while using the stock ride height?
Thank you
Old Aug 7, 2013 | 10:01 AM
stuartc323's Avatar
stuartc323
Thank you
Camber at -1.8 front, -2.0 rear
Caster at 8.8 or 8.9
Toe at 1/16th out for front, in for rear
Add sway bars, get harder bushings, get better tires, get better shocks. Car will move whatever way you want it to after this
Remember also the higher you go in negative camber, the more your tires will wear.
Old Aug 7, 2013 | 01:18 PM
ChrisNelson
Thanks for the input. Is this a pretty standard setup (alignment spec wise) or does anyone else have some opinions?
liqalu04
Jan 2, 2022 12:58 PM
Depravity
Oct 1, 2015 04:49 PM
