Brembo vs Project Mu vs Endless?
OEM Brembos all the damn way. Very few people make enough HP or race enough to warrant another set up. A good set of pads go a LONG way and the pad, rotor, and line combination for the Z is plentiful. I'd highly avoid Mu and Endless as the initial investment is cheaper than part availability and cost of ownership is astronomically high. Powerslot Rotors, Goodrich lines, and whatever compound pads you need are the best, economical and smart way to invest money into a braking system.
Easy math here... maintenance parts:
Endless Rotor = $1k each
Endless Pads = $700 front set
Endless AN Brake lines = $400
VS:
Powerslot Rotors = $400.00 a Set
EBC = $250.00
Goodrich lines =$150.00
I had a set of Endless/HKS 6/4pots with 2 piece rotors and AN lines on mine... they were loud, dirty and squeaky. Mu is just for looks and parts are difficult to obtain. I'd avoid all the "baller JDM" brands completely for that very reason. If I did it again I'd probably stick with OEM Brembos or probably StopTech Trophy's... not because I needed them(90% of us here only "need" 06+ brakes), only because I can afford them. Alcon and AP are nice EU offerings but again... expensive and hard to get parts for. Good luck.
VS:
EBC = $250.00
I agree the initial investment is stupid on Endless, but I gotta disagree on the loud, dirty and squeaky! I've been running the Endless R6/R4 setup since '08 with no issues. No more dirty than a good set of pads on any other setup, and no noise at all. That said, I do agree that you can get something just as good for alot less...
04-04-2016 07:52 AM
