End Links Question
Old Nov 6, 2013 | 06:15 PM
Nj350track's Avatar
Nj350track
Default End Links Question
I am in the process of putting BC Racing coil overs on my 03 350z ... I got the coils on but trying to get the right heights on my 20" xxr's... I cannot go lower due to the stock end links not allowing me to put the bolt back onto the bottom of the arm and coilover... The stock end link when attached is throwing off the bolt holes for everything else... Is it a must to buy adjustable end links when lowering ... or is something wrong here... Thanks
Old Nov 6, 2013 | 07:19 PM
JasonZ-YA's Avatar
JasonZ-YA
is the entire front of the car off the ground when your trying to install? try with the front of the car off the ground then reinstall.
also, even if you do get them in - yes you need shorter- ie, the endlink shafts that go in the swaybar and the lower translink arm are not gonna be 90 degrees, they are gonna be pitched in..signifying that the stock oem endlinks are too long..
-J
Old Nov 6, 2013 | 07:32 PM
Nj350track's Avatar
Nj350track
awesome .. just spoke with my friend... said the same... I did have both sides jacked up but one side still had a wheel on it... he said try to jack up the other arm just to get some stress off the bar and take off both wheels... hopefully this works and thank you for the reply !
Pleask
Dec 21, 2021 03:17 PM
issyz
Jul 2, 2017 03:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Li1ag
Sep 28, 2015 02:07 PM
Tochigi_236
Sep 27, 2015 03:40 PM
