Akebono bracket question
Old Feb 9, 2014 | 03:46 PM
G4nismo's Avatar
G4nismo
Default Akebono bracket question
I'm looking to buy the akebono BBK soon so i been reading up a bit on it but got a question about the adapter for those that have installed these.
Does it matter which adapter i get between the CZP brackets and the Z1 brackets? CZP are 4 pieces and looks like the Z1 are 2 pieces.
CZP:
http://conceptzperformance.com/Cart/image.php?II=3411
Z1:
Old Feb 9, 2014 | 04:13 PM
350zchad's Avatar
350zchad
dont think it'll matter, I bought my set off ebay and has performed flawlessly at a much lower price
you will need those little moon shaped pieces, I'd call z1 and ask why they aren't pictured
Old Feb 9, 2014 | 04:20 PM
Waiz's Avatar
Waiz
As stated from the Concept Z page:
"These Brackets are used to Mount the Front 14" Akebono Brake Kit that is available on the 370Z/G37 Sport Models. Other brackets on the market take shorcuts and don't incorporate a spacer so a washer can be used like the OEM setup. This can be very dangerous, as the bolts can get loose and cause further damage. The brackets are a direct bolt on and perfect fit. All hardware and instructions are included."
Those extras in the Concept Z kit are the washers I am guessing
Old Feb 9, 2014 | 04:31 PM
G4nismo's Avatar
G4nismo
how long have u been running yours? is this where you got yours?
http://www.ebay.com/itm/350Z-G35-BRAKE-UPGRADE-G37-370Z-AKEBONO-BIG-CALIPER-FRONT-ADAPTER-BRACKET-/321303961286?pt=Motors_Car_Truck_Parts_Accessories&hash=item4acf355ec6&vxp=mtr
Old Feb 9, 2014 | 04:33 PM
G4nismo's Avatar
G4nismo
the way they worded it sounds confusing to me. when they say washers, are they referring to the washers for the bolts and by spacers the two half moon shaped things?
Old Feb 9, 2014 | 04:38 PM
samsniss350z's Avatar
samsniss350z
I totally agree with Waiz in that the washers, not being lock washes are prone to coming loose and are therefore dangerous and I for one would not be comfortable using flat washers. Although saying that, the kit looks pretty well made.
Old Feb 9, 2014 | 04:42 PM
350zchad's Avatar
350zchad
I've had mine on for almost 2 years.. and the ones on ebay that you posted look similar. I cannot remember the seller name.. and you have to have the moon shaped pieces. I have checked mine and never had a problem with them loosening.
Old Feb 9, 2014 | 04:49 PM
350zchad's Avatar
350zchad
this was the seller.. doesn't look like he has these listed anymore.. you could email him to see if he could make you some.. I paid 150
http://www.ebay.com/usr/newlivemarket
Old Feb 9, 2014 | 05:50 PM
beezee's Avatar
beezee
I had mine from CZP as well. They came with some instruction which I used with
the DIY I read here. Made install Easier
Old Feb 9, 2014 | 05:55 PM
350ZZJoe's Avatar
350ZZJoe
I have the CZP brackets on mine, they work just fine. Have held up over a a few track days as well so I can at least vouch for them!
Old Apr 21, 2014 | 09:17 PM
Cobraredz's Avatar
Cobraredz
Reviving a what seems like dead thread. Anyone else find a different seller other than ZCP that seeks these? Just moved over from the g37 forum and still have my akebonos with pads and rotors I'd like to toss on my z
Old Apr 22, 2014 | 09:56 AM
350ZZJoe's Avatar
350ZZJoe
Man, in the very first post, the OP was comparing the CZP bracket to the Z1 bracket. And then a response discussed an eBay bracket.
Did you not read anything?
Old Apr 22, 2014 | 10:36 AM
Cobraredz's Avatar
Cobraredz
I should've been more specific I'm trying to buy some like these
http://m.ebay.com/itm?itemId=221388485062
CZP and Z1 are asking double that for the same bracket I'd just buy some locking washers.
Old Apr 22, 2014 | 01:20 PM
350ZZJoe's Avatar
350ZZJoe
Oh okay. I don't know of any shops that sell cheap brackets. Quite frankly, I wouldn't skimp out to save only $100 when installing such expensive brakes on my car.
I guess just keep your eye on eBay for a set then if that's what you want.
Old Apr 24, 2014 | 08:54 AM
Waiz's Avatar
Waiz
I would not buy an ebay set from a no-name vendor
These are so critical in mounting the brakes that you don't want to cheap out. With either the Z1 or CZP you are assured that 1) you are supporting a forum vendor 2) they stand behind their product if something goes wrong
Old Apr 24, 2014 | 01:07 PM
350zchad's Avatar
350zchad
i bought mine on ebay.. perfect fit, no problems in 3 years. but as said they aren't that much different in price so buy from an established vendor if none are on ebay currently get it from a vendor or used from someone selling them off
Old Apr 28, 2014 | 02:37 PM
Cobraredz's Avatar
Cobraredz
Yea I'm gonna keep my eyes open it's more of a flashy look thing more than anything my oem brakes stop perfectly fine just as they did when I had the akebono. Otherwise I found that West Covina Nissan (nismo shop) sell em too http://www.thenismoshop.com/Concept-...it_p_1897.html so that's a third audition just wondering if they support the forum just like the other two do.
