Lame rear suspension questions
Old Feb 11, 2014 | 10:43 AM
GUNDIE's Avatar
GUNDIE
Default Lame rear suspension questions
I have an 08z and not sure I fully understand what links I need for the rear I ordered oem style coilovers and spl rear camber arms. When keeping oem bucket do I run adjustable toe rods too I ordered the spl but canceled
figured I'd ask first cause after reading the description was talking about only running on "ras" and true coilover style. So do I need them or what
Thanks!
Old Feb 11, 2014 | 11:10 AM
pyshin's Avatar
pyshin
No, you do not need rear toe links; those replace the spring bucket link for true rear coilover setups. You will need a toe bolt kit (probably SPC http://conceptzperformance.com/Cart/...on.php?II=4290) so that you can get your alignment back to spec.
If you're interested, SPL also makes high performance mid-links to replace the stock spring bucket link: http://www.splparts.com/chassis-Z33.html#SPLRMLZ33
Old Feb 11, 2014 | 11:11 AM
GUNDIE's Avatar
GUNDIE
Appreciate it the coils were on back order anyways I'm seeing I can switch to true style. I was being lazy I researched a little bit thanks man!
Old Feb 11, 2014 | 11:15 AM
pyshin's Avatar
pyshin
No prob. Also read through this thread: https://my350z.com/forum/brakes-and-...ion-101-a.html
You probably won't need to post amateur questions afterwards. Good luck
Old Feb 11, 2014 | 12:06 PM
GUNDIE's Avatar
GUNDIE
Wellll that pretty much covers everything hahah
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
CJs_Z33
Sep 18, 2015 12:06 PM
