brake pads not making full contact
on
after having my wheel baring/assembly and break pads changed. i started to get rust on the outter part of the rotor. even from breaking i cant get the rust off. any help?
![](https://my350z.com/forum/images/ranks/premier.gif)
![](https://my350z.com/forum/images/ranks/moderator.gif)
Your BRAKE pads probably have a beveled upper edge and will take time to wear in. Either that or as mentioned above, also when your BEARING was faulty it cause the pad to hit a little bit more of the rotor than you would have with a good bearing.
Tochigi_236
09-27-2015 03:40 PM
