higher end coilovers for street choices
Old Apr 2, 2014 | 04:50 PM
overZealous1's Avatar
overZealous1
Default higher end coilovers for street choices
ok, i have been fighting off doing a thread on this but after literally about 15 hours over the last couple days searching and reading i am needing a little personal experience reviews about what may be best for me and my driving.
the high end of my budget allows for a set of ohlins, but wanting to just make sure this is a good choice.
about the car- it started as a 2005 g35. it is under going a full rebody that only uses the basic infiniti drivetrain and floor pan. i will be going straight into a tt ls swap with 6l90 6spd auto. weight balance may come out a tad front heavy with about the best i can get it is about 55% front when done and a finished weight around 3200. tires 275/30/20 and 325/25/20.
about my expectations and driving- i really do not plan to competitively drive the car. maybe some autocrossing, few track days here and there, but mostly street. yes, i know how to drive and used to be very competitive in autox so i do know the difference in **** parts and can drive them to the limit.
what i am trying to achieve- i do not want something so stiff i skip across bumps while on the street. i want something that will be very precise, but not super stiff. i can control body roll with the sway bars. i know in my price range there is lots of choices and if i can get away with something quality for less than the ohlins i am all ears. i am still waiting for delivery of the car but guess i will want to drop in the 2-2.5" range.
btw- air is not out of the question either. car will be low with a front splitter also and my driveway is a *****. so the ability to raise is a plus if others think that works for my requirements.
thanks for the replies. really looking for good insight on this.
Old Apr 2, 2014 | 05:34 PM
Sickboy101's Avatar
Sickboy101
I would recommend the KW V3s... Then again I'm biased as that's what I'm running.
Old Apr 2, 2014 | 05:48 PM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
IIRC KW 3 max drop is 1.5 all around. OP wants something 2" or lower. Correct me if I'm wrong but I notice the higher end coils doesn't go lower than 1.5", look into stance/bc racing coils if you're looking for 2+ inch drop but you're sacrificing quality, pick a poison.
Old Apr 2, 2014 | 05:56 PM
npr350z's Avatar
npr350z
so silly question/ thread jack... why would all the high end coil overs only drop a z 1.5'? is that all thats allowed in the classes the coils are used in? or is that all the z really needs?
Old Apr 2, 2014 | 05:59 PM
stogey420time
Club Moderator
the Hot Spot
From what I've gathered on the forum, any drop lower than ~1.5"... You're fckin up the suspension geometry so a car.
Old Apr 2, 2014 | 06:33 PM
overZealous1
in general, if you go to far you bring the shock out of it's sweat spot. that is probably the main reason. the camber/caster gain will be greater than the stock designed geometry or "start point" if lowered. i am not too concerned about going just a little lower, but yes, i would like a set up that ride height is adjusted via the mount, so the shock will be in it's designed range. i have also noticed that many of the coilover perches allow enough space to redrill holes higher up on the forks. i could get probably another 3/4" out of redrilling mounting holes higher.
again, this is a full rebody so i cannot gauge the amount i want to visually drop until having car in hand. it is radically different than a g35, lol.
when i had my tt 350z i had about a 3" drop on it with tanabe springs and stock shocks. bumpsteer was effected, but very little. geometry still felt good, camber and caster gain just happens faster but with a stiffer spring it limits it.
Old Apr 2, 2014 | 08:46 PM
csy's Avatar
csy
I had the ohlins dfv installed a month ago... its well worth the money for street/track usage.
Old Apr 2, 2014 | 09:49 PM
overZealous1
that was going to be my other choice. a little less money also.
Old Apr 3, 2014 | 01:43 AM
terrasmak's Avatar
Anything off the shelf should probably be revalved and resprung for your added weight
Old Apr 3, 2014 | 01:56 AM
03threefiftyz's Avatar
03threefiftyz
With the big price drop on the Ohlins, there is really no reason to consider getting anything else in the sub 2500 category IMO.
Old Apr 3, 2014 | 04:42 PM
overZealous1
if i stayed with the g35 drivetrain, the car would come in at 2900lb wet with about a 62-65% front bias. by the time the ls and mid mounted turbos (they will be where the original rear seat footwell is) then some air/water intercoolers, it gives me alot of ballast to put water tank, battery and stereo amps in extreme rear to help the balance. so at the end of the day i should still be less than the stock g35.
Old Apr 3, 2014 | 04:52 PM
overZealous1
ok, thats kind of what i wanted to hear. i know the ohlins would be a great set up, was just checking to see if there should be any other coilovers to consider.
Old Apr 3, 2014 | 06:03 PM
dmsec's Avatar
dmsec
Ohlins are going for under $2500 now?
Awesome, last I knew they were still over $3000.
Old Apr 3, 2014 | 06:46 PM
overZealous1
quite a few places going $2642 before shipping. most of them are the same $2642 or higher so it must be the lowest advertising price ohlins will allow.
Old Apr 15, 2014 | 05:46 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Any insight as to who carries these currently, also awesome to see you back on the forums!
What about KW clubsports?
Old Apr 15, 2014 | 11:53 PM
terrasmak's Avatar
Race Consulting Agency carried both Ohlins and KW , I don't think they are a forum sponsor and I don't think we have a vendor that carries both.
Old Apr 16, 2014 | 02:55 AM
Vq.turbo.DremZ
Just checked, they do not seem to have the ohlins listed but I meant that the KW clubsports were a suggestion to overzealous.
You still have the motons?
Old Apr 16, 2014 | 06:14 AM
terrasmak's Avatar
I bet they carry them. Really I would get the car on scales and do a full proper suspension workout on it
Old Apr 16, 2014 | 08:36 AM
Adam @ RCA's Avatar
Adam @ RCA
Thanks terrasmak!
We have 2 websites.
our Coilover-Store has Ohlins listed.
http://coilover-store.com/product/oh...2008-nis-mi00/
All other goodies including KW's and much more is listed on our Race Consulting page.
http://raceconsultingagency.com/kw_s...n/b-10118.aspx
Our shop is in Chicago and we specialize in suspension and racing setups and helping guys get on the track.
If there is anything I can do to help please let me know.
Currently we are talking to IB on a few different scenarios for marketing and advertising on the boards. I am very familiar with my350z. Had a lot of history with this forum.
-Adam
