Adjusting adjustable end links
Old Jul 2, 2015 | 05:31 AM
CptWiggles's Avatar
CptWiggles
Default Adjusting adjustable end links
Somehow I posted this in the 370z area, but here it is.
1) With the car at rest disconnect one end of one end link on each axle. This will remove any torsional load on the sway bar.
2) Loosen the jam nuts and adjust the end link until it can be re-connected without moving the sway bar from its resting position.
I understand all of the above, but I can't find what the "resting" position is. The sway bar itself swivels about 90 degrees when not connected to any end links, so what is the correct position or angle to place the sway bar?
Old Jul 2, 2015 | 05:43 AM
terrasmak's Avatar
Shorten endlinks, do the above but only remove 1 side. Adjust to install the endlinks with no load on it
Old Jul 2, 2015 | 05:49 AM
CptWiggles's Avatar
CptWiggles
I understand the basis of the procedure, my question is my car is now lower than stock, how should the end of the sway bar be oriented, for example, should the end where the holes are be parallel to the ground, 45 degrees upward, etc. Because the end links are adjustable I am able to connect the sway bar with no pre load in a variety of different angles, which is the right one?
Old Jul 2, 2015 | 05:52 AM
CptWiggles's Avatar
CptWiggles
Also, I'm no physicist, but I'm assuming that by changing this angle when the car is in it's resting position it probably has some sort of effect on the amount of force on either the bar or end link which is why I'd like to try and get it right.
Old Jul 3, 2015 | 12:36 AM
terrasmak's Avatar
As you lower the car you need to shorten the endlinks to get the angle back to stock, well the endlinks are short from the factory. At the shortest setting, it's hardly shorter than stock.
Old Jul 7, 2015 | 07:43 PM
pfregeolle's Avatar
pfregeolle
You're not helping or answering his question at all.
He's asking what angle the sway bar should be positioned at in regards to the rest of his suspension components.
Even with one side disconnected, the other attached side can still be shortened or lengthened and in turn position the actual sway bar at different angles. Then the other side can be adjusted to slide back into the lower control arm hole with no preload.
My guess would be to attempt to get the ends of the sway bars positioned parallel to the ground, but that's just my guess and will probably be the route I go with when I install my Whitelines.
Old Jul 7, 2015 | 08:09 PM
superlim9's Avatar
superlim9
sway bar ends should be horizontal... end links should be as vertical as possible.
the reason is because it makes application of forces more linear at right angles
Old Jul 7, 2015 | 08:21 PM
pfregeolle's Avatar
pfregeolle
^^BOOM! Thanks superlim for being helpful!
Old Jul 7, 2015 | 08:41 PM
nizmo_0385's Avatar
nizmo_0385
Awesome info have whiteline links ready to go as soon as i find a drive on lift in my area
Old Jul 7, 2015 | 10:50 PM
terrasmak's Avatar
As kinda mentioned above, not really possible with the Z. The endlinks would need to be an inch shorter than they are made
Old Jul 8, 2015 | 08:56 AM
CptWiggles's Avatar
CptWiggles
Lol, thanks for getting us there.
Old Jul 15, 2015 | 02:35 AM
nizmo_0385's Avatar
nizmo_0385
Brand new endlinks pop too. Im not sure if too long or too short. They went in easy and seemed to have no load yet after 1 day the driver front and pass rear pop. Anyone have any tips...
Old Jul 15, 2015 | 03:11 PM
superlim9's Avatar
superlim9
only thing i can say is check everything for any wear/contact and make sure the mounting bushings are greased and tight. Also the Jam nuts need to be as tight as possible. Check where it bots to the arm and sway and make sure they didnt come loose. A lot of guys tend to have that issue on occasion with it coming loose on them
Old Jul 15, 2015 | 04:24 PM
nizmo_0385's Avatar
nizmo_0385
Ahh thanks sir. Jam nuts were hand tight only. Tightened them after straightening the link as it turned. So far so.good.
Old Feb 4, 2016 | 05:12 AM
RobPhoboS's Avatar
RobPhoboS
I've got to re-adjust my ones on Saturday as I've been getting some little clunk sounds when at very slow parking maneuvering speeds.
I think this picture gives you the idea as well as what others have said.
apex locator
Jul 23, 2021 02:27 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
pr_350z
Oct 1, 2015 05:03 PM
Tochigi_236
Sep 27, 2015 03:40 PM
