Sounds like stuck caliper?
Old Dec 3, 2015 | 10:32 PM
Timmy Tran's Avatar
Timmy Tran
Default Sounds like stuck caliper?
Hi, I started smelling burnt brakes while driving home from school, then my gas pedal has a slightly weird vibration and it made it slightly difficult to accelerate. Once I got home, I did a walk around, and what I found out is there is a lot of heat and smell coming from the Rear Driver Side brakes. Upon further inspection, the rotor of the same corner is scratched. I searched the forums and it seems like all signs are pointing to a stuck caliper. Are these pretty good signs that its the caliper getting stuck?
Also, I went ahead and searched for replacement calipers. I came across a pair of USED 06-08 rear calipers for 85$. versus one NEW 03-05 Rear Driver Side caliper for 45$. Both of which were on Ebay. Which of the two would you 350z gods choose if the problem turns out to be a stuck caliper? If I were to buy the 06-08 pair, will my 03-05 akebono pads fit them?
Old Dec 3, 2015 | 11:34 PM
terrasmak's Avatar
03 to 08 non Brembo rear calipers are all the same.
I would probably grab the rebuilt one
Old Dec 4, 2015 | 07:03 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
^^^ Yup, agreed.
Used calipers *should* always be rebuilt anyways. No telling how long they've sat and with any mileage, the pistons and seals could use a refresh. Never cheap out on brakes or tires. Never.
mariar508
Wheels Tires
Dec 28, 2015 06:57 AM
Dec 2, 2015 09:20 PM
DarkCreep
Nov 17, 2015 11:04 AM
35th4me
Nov 16, 2015 12:01 PM
Frankd1210
Nov 11, 2015 01:33 PM
