oem nismo rear springs
Old Mar 5, 2016 | 11:31 PM
nizmo_0385's Avatar
nizmo_0385
Default oem nismo rear springs
Im installing my oem nismo suspension and i have a dumb question. Which way does the spring sit in the rear bucket. I currently have the bunches of coils at the top is this correct?
Just want to verify thanks
Old Mar 6, 2016 | 11:49 AM
Spike100's Avatar
Spike100
It shouldn’t make any difference if they fit either way; the softer part of the spring will compress first, regardless of it's being on the top or bottom.
I would say you should install them so that you can read the lettering on the spring.
Old Mar 6, 2016 | 11:54 AM
nizmo_0385's Avatar
nizmo_0385
Thank you. I looked for words there are none.
Old Mar 6, 2016 | 12:34 PM
travlee's Avatar
travlee
Master
when i did my eibach's... i did them to where i could read the logo... so that would but the tighter loops at the top (assuming nismo are the same)
Old Mar 6, 2016 | 01:50 PM
Spike100's Avatar
Spike100
I see something (labels or printing) on the springs in the pictures you posted.
You can mount the springs either way (there will be no difference in performance as long as they fit).
Old Mar 6, 2016 | 02:02 PM
nizmo_0385's Avatar
nizmo_0385
Ok thanks. There is just colored dots on them.
But thank you going to button it all up
Old Mar 6, 2016 | 02:20 PM
dcains's Avatar
dcains
You'll see that one side of the spring matches the seat in the A-arm, and the spring also has to be rotated properly to fit fully down in the seat. It's been several months since I've had mine apart, so I don't remember which end is up, but it will be obvious to you when you're in there.
Old Mar 6, 2016 | 06:58 PM
NiLL's Avatar
NiLL
My nismo with the OEM stuff has the coil wrapped in rubber up top. If you care.
Old Mar 6, 2016 | 08:52 PM
nizmo_0385's Avatar
nizmo_0385
Thankyou sir. That is how i set mine up.
Old Mar 6, 2016 | 08:53 PM
nizmo_0385's Avatar
nizmo_0385
Thank you
Nackers
Mar 12, 2016 03:45 PM
ivanorcan
Mar 5, 2016 08:20 PM
Carl__96
Feb 29, 2016 09:23 AM
