Early 04 Roadster Rear OEM Spring Help
Old Oct 13, 2016 | 04:06 PM
WolverineFour's Avatar
WolverineFour
Default Early 04 Roadster Rear OEM Spring Help
Rear Coil Springs
2003 - early 2004 Nissan Part # 55020AM820 - Spring Rate 342
2004.5 - 2007 Nissan Part # 55020AM821 - Spring Rate 427
Nissan Part # 55020AM821 Superseded to 55020AM82B
I have an early 2004 Roadster with 5020AM820 (342 spring rate). I want to install OEM springs with the 427 spring rate. I can order 55020AM821 or the superseded part # 55020AM82B. Both are available. I'm having trouble finding out what is the difference or why the part number changed. Was there another change in rear springs in later years that I'm not aware of?
Old Oct 13, 2016 | 07:29 PM
jhc's Avatar
jhc
General & Tech Moderator
Don't waste your time and money. Get the Eibach Pros for $300 and change. A much stiffer yet comfortable ride, slight drop.
Welcome btw.
Old Oct 13, 2016 | 08:27 PM
dcains's Avatar
dcains
+1. I would imagine Nissan will charge more for 2 OEM springs than you'd pay for a set of 4 quality aftermarket springs.
Old Oct 13, 2016 | 08:28 PM
WolverineFour
I really didn't want to drop it... even a little. I just installed 275/40-18 with +15 offset. I have a rub on the passenger side when I accelerate or get into the corner. Seems to me that with the stock suspension this should not be happening. My belief is that the earlier lighter spring is the culprit.
Old Oct 13, 2016 | 08:32 PM
dcains's Avatar
dcains
That seems odd - sure they're the stock springs? I wonder what sort of condition the shocks and bushings are in on a car of that age, too. Is the alignment to spec?
Old Oct 13, 2016 | 08:40 PM
WolverineFour
Great question Dean. I have not had the alignment checked. I bought it with 36K couple of months ago.
Old Oct 13, 2016 | 11:18 PM
dcains's Avatar
dcains
There might be something going on. That's not a real aggressive tire size, and I have the same on my '08, with 18 x 9.5 +30 wheels. Suspension is Nismo (not lower), which is a stiffer than original, but the fender isn't close at all. Maybe that 15mm offset difference is the problem? You might be able to roll the fenders ane be fine.
Old Oct 14, 2016 | 07:32 AM
WolverineFour
jhc looks like you have a roadster as well...was looking at your album..you have much more aggressive offset/tire combination than I'm trying to run...from what I can tell from the pictures. What setup are you running?
Old Oct 15, 2016 | 05:06 AM
jhc's Avatar
jhc
Correct. Eibach Pro's and stock shocks (about to replace w Tokiko blues, dd still).
Enkei 9.5x18 +12 FR, 10.5x18 +12 RR
265/35 FR, 295/35 RR with a roll.
The good news, I can drive as hard as I want.
The bad news, noticeably slower off a line than my smaller setup.(225/245)
Old Oct 15, 2016 | 03:14 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I have 9.5 +15 offset I had to roll my rear fenders.. 265/40 rear tires... Also lowered.
Rolling the fenders would be better then swapping factory springs for factory springs.
Old Oct 15, 2016 | 05:59 PM
jhc's Avatar
jhc
Z's lookin damm nice in that beautiful Fall pic, sir!
350zdorifto
Interior
15
Apr 6, 2017 09:17 PM
Loki05
Accessories
Dec 29, 2016 02:11 PM
Cannysage
Oct 16, 2016 11:37 AM
