Why no 350 brake duct cooling kits?
Old Feb 3, 2018 | 12:15 PM
Franknbeans's Avatar
Franknbeans
Question Why no 350 brake duct cooling kits?
I've been searching for a while now and noticed there isn't a brake duct kit for the 350z. There's kits for many other cars, including the 370 but not one company has put together one for the 350.
I realize it's not very hard to do or to put together a kit of your own, but it would be nice just to go to one place and be done.
Old Feb 3, 2018 | 03:25 PM
terrasmak's Avatar
There have been a couple over the years.
Old Feb 4, 2018 | 07:41 AM
Franknbeans
Might of been, but there's nothing out there now.
Old Feb 4, 2018 | 07:51 AM
guitman32's Avatar
guitman32
In the aftermarket its tough with kits that can easily pieced together, like oil cooler kits, with very few proprietary pieces. They can easily be copied for cheaper and the race to the bottom begins. The electronic Roo-ducts are still available, though I have no personal experience with them.
Old Feb 4, 2018 | 05:09 PM
rancor's Avatar
rancor
https://parts.nissanusa.com/nissanpa...catalogid=2370
Or are you looking for tubing an intakes also?
Old Feb 4, 2018 | 05:24 PM
Franknbeans
I need to pull the bumper off and look but yeah, I was looking for a complete kit with tubing, intake, mounting, directions... but no one does it....
Old Feb 5, 2018 | 04:38 AM
guitman32's Avatar
guitman32
Pretty sure this item is no longer made or available. But worth a check its been a while since I have. Part# is 63822Z33RS
Old May 17, 2018 | 03:59 PM
SpartaEvolution's Avatar
SpartaEvolution
Searching that PN on google brings up literally only one result.. and that result is this thread haha
Old May 18, 2018 | 05:05 AM
guitman32's Avatar
guitman32
Yeah not surprising since it was a 100% custom piece...you can still call NissanRaceShop at Fontana, but theyll tell you to just keep your eye online for a used set. Last I spoke they confirmed the molds were sold some time ago. But these arent really that hard to fab...they may not look quite as nice but laying something up should be pretty easy.
The problem is cost...carbon isnt cheap. I tested some plastic ducts of similar design that Randy of Rooducts made for me. They melted as he said they would, but he wanted to test some high temp plastic. In fact they held up surprisingly well, and with a little insulation should hold up.
There are also a lot of people/shops making some nice things ive seen on social media. Full cf pieces that replace the stock heat shield. Though I dont believe keeping the heat/dust shield is necessary (except for ABS sensor clearance), and Ive mounted 2.5in ducts straight to the spindle with surprisingly good results, which isnt optimal but is essentially free.
Old May 18, 2018 | 07:37 AM
SpartaEvolution
Yeah, I've been kicking around the idea of building a set for a while, just haven't gotten around to pulling the bumper and figuring our the routing et al. In a naive state of i-don't-know-what-im-doing-ness I cut up my old rev-up airbox so I could fit a cone filter but retain the factory ram-air, so I have one large velocity stack that I was going to use as an inlet, the problem now is I don't want to cut up another rev-up airbox seeing as the actually hold some value, so I'll have to use a mis-matched set. I don't think the stacks will make much difference since the air has to flow through flex tubing anyways, but aesthetically I wanted to have.. *ahem* .. two fat stacks.
Old May 19, 2018 | 09:27 AM
guitman32's Avatar
guitman32
Definitely seems like some work. Heres a pic of the bootleg fix after those ducts melted. It was pretty rushed, but surprisingly they held up without issue. You can see where I tapped the knuckle to fasten the ducts normally.
Hotlaprc
Aug 13, 2015 05:03 PM
POWERSLIDIN
Oct 16, 2008 09:23 PM
