Diff abs sensor info
Old Nov 1, 2021 | 02:40 AM
evilscorp's Avatar
evilscorp
Default Diff abs sensor info
Looking to use the abs sensors in the 350z diff to get a speed signal for my nissan s14a speedometer.
My setup is SR20det- 350z 05 CD00* gearbox- 350z carbon prop- 350z diff- 350z driveshafts.
I am using a dekota digital speed converter SGI-100BT to try and convert the signal to send it to the oem speedometer.
I have tried a few ways to wire it up but not having any luck and still waiting for a reply from their tech help.
I can send a calibration (TEST) signal from the SGI which then shows on the oem speedometer (albeit at half the value but I should be able to adjust this when properly setup).
The issue I am having is that the 350z 2 wire abs diff sensor I believe require a 8V power and a signal wire but there are no write ups for setting up the SGI when the sensor requires power sent from the converter(SGI).
I tried putting the abs sensor inline of the oem automatic trans speed signal but I dont think it sends 8V.
I have tried wiring the sensor to the SGI ground and signal inputs, and the SGI positive and signal inputs but have yet to get any signal.
I did see 0.4V between the input (positve voltmeter connection) and SPD - (SGI ground) (negative voltmeter connection). But I dont think I could scale it up to give a proper signal or if its even a signal.
Anyone have any info on the abs sensor operation that would be great.
(I also have a 350z but unable to start it so cannot get voltage readings from its sensors for comparison.)
Thanks.
treimche
Apr 10, 2020 05:29 AM
Cookiezor
Apr 25, 2015 04:47 PM
cjb80
Dec 2, 2004 07:22 AM
fluidz
Jan 29, 2004 07:13 PM
350ZSC
Oct 12, 2003 09:13 PM
