03 350z Hydraulic ebrake
Old Aug 7, 2024 | 06:36 PM
ReallyCoolName's Avatar
ReallyCoolName
Default 03 350z Hydraulic ebrake
Hey, I installed a hydraulic ebrake and now lt seems all the pressure on the brake pedal and hand brake doesnt is gone until I pump up the foot brake. After I pump it up then it will hold the pressure until I let go of the brake again and lose all pressure in the handbrake and foot brake. Anyone have any ideas on the issue or hopefully simple fix? Lol. Thanks
Old Oct 25, 2024 | 02:58 PM
Enriquez2000's Avatar
Enriquez2000
1st mistake was making it an inline hydro... niw if you lose pressure you lose both.
Sounds like you have a leak, bleed off or air in lines. You need to rebleed the whole system and check all fittings are tight.
Follow standard bleeding procedures with hydro being last bleed.
Zclumpy
Jul 18, 2017 04:25 PM
_Ishy_
Sep 30, 2016 04:43 AM
Chomorro
Apr 29, 2009 09:58 PM
Escobar
Nov 12, 2005 12:51 PM
