FYI- what ball joint removal kits to borrow from AutoZone to remove ball joints
Old Sep 9, 2024 | 02:08 PM
CFAUVEL's Avatar
CFAUVEL
Default FYI- what ball joint removal kits to borrow from AutoZone to remove ball joints
Just wanted to share what kits I had to borrow from autozone to successfully remove and install the lower ball joints on my 2005 350z.
I had to go back several times to rent additional adapter kits.
I think most of these kits are meant for USA cars/trucks.
Here are the kit numbers I used ...it may save you time in getting the right tools.
Base kit
Adapter Kit
removal setup
Install setup
Old Sep 9, 2024 | 07:02 PM
icer5160's Avatar
icer5160
Really good information! Thanks for sharing! This should get pinned in the DIY - Brakes/Suspension section or under 350Z Tech - Brakes/Suspension section.
Cheers!
-Icer
Old Sep 10, 2024 | 05:18 AM
CFAUVEL's Avatar
CFAUVEL
Cheers!
-Icer
Thanks....I looked around for some guidance as to which press kit to use and couldn't find anything so I figured I'd share what I found that works.
Old Sep 13, 2024 | 09:08 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Cheers!
-Icer
Agreed, some helpful info here. Now stickied in Suspension section for those who need a BJ or both. Wait, what? I meant ball joint, ahem. Get your mind out of the gutter.
Old Sep 16, 2024 | 10:36 AM
mcubed45's Avatar
mcubed45
Thanks that's awesome! The hardest part is finding the adapter that fits around the BJ for removal. My autozone didn't have the adapter kit even though I went to 3 different ones and oreilly's. I ended up making one out of a 2" pipe coupler as someone else mentioned (grind off the threads).
Bmsluite
350Z Roadster
Jul 25, 2020 02:24 PM
dboyzalter
Apr 25, 2018 03:20 PM
trusovici
Dec 26, 2017 07:05 PM
bishop_98
Aug 10, 2017 10:35 PM
paul44
Jul 22, 2014 03:16 AM
