Front BBK
Old Dec 8, 2025 | 10:41 AM
ChocolateCowboy's Avatar
ChocolateCowboy
Default Front BBK
Do people still run the BBK on the fronts only like the civic guys or has that trend faded away like the StreetGlow? just wondering....
Old Dec 8, 2025 | 05:11 PM
DarkZ03's Avatar
DarkZ03
You shouldn't, unless the kit is designed around the stock rear.
Old Dec 8, 2025 | 05:38 PM
ChocolateCowboy
I have seen kits through conceptZ just the front BBK kits
Old Dec 9, 2025 | 05:09 AM
Heel Til I Die's Avatar
Heel Til I Die
StreetGlow isn't cool anymore? Aw man. Nobody tells me nothin'.
Old Dec 9, 2025 | 05:19 AM
ChocolateCowboy
Lol.. I love streetglow.. I dont care how not cool it is.. I am getting some!!!! Nfs underground
Old Dec 9, 2025 | 05:31 AM
Aeneas137's Avatar
Aeneas137
I recommend Akebonos all around but be aware they won't fit under all wheels. remanufactured calipers are only about $300 per pair. The mounting brackets / banjo bolts can be sourced from Z1 or CZP.
Old Dec 9, 2025 | 06:23 AM
ChocolateCowboy
I run 19x9.5 front and 19x10 rear.. I should be good on wheel size.
Old Dec 9, 2025 | 06:30 AM
GreyZ's Avatar
GreyZ
Its the face shape, not the wheel size that matters. I had some 18x10.5 that would not clear stock brembos and needed spacers. Aeneas brings up a good concern.
Old Dec 9, 2025 | 06:57 AM
ChocolateCowboy
ohhh the offset for example +22
Old Dec 10, 2025 | 07:55 AM
GreyZ's Avatar
GreyZ
Face shape. Not Wheel size. The literal shape of the spokes determines if they will clear. What wheels are they?
Old Dec 10, 2025 | 07:59 AM
ChocolateCowboy
LE37s 19X9.5 FRONT 19X10 REAR +22
Old Dec 10, 2025 | 02:10 PM
Aeneas137's Avatar
Aeneas137
Enkie RFP1 18s would not fit over the akebono calipers. looking back on it now, I probably could have used 3mm spacers but I didn't think about it at the time. I switched to different wheels.
Old Dec 10, 2025 | 05:20 PM
ChocolateCowboy
ooooooooo
Old Dec 11, 2025 | 05:34 AM
Heel Til I Die
If you're going with the Akebono 14" BBK, here is the template for the front wheels so you can determine whether the calipers will clear. Print it out and put it on some rigid material like cardboard.
Pretty sure you'll be ok with your LE's, but it would be a good idea to confirm before pulling the trigger.
File Type: pdf
Old Dec 11, 2025 | 05:50 AM
ChocolateCowboy
Yes sir, thank you.. I will look into that!!
Old Dec 11, 2025 | 06:19 AM
ChocolateCowboy
I really cant decide if I want the AKEEBONOS or the BREMBOS
Old Dec 11, 2025 | 07:35 AM
Heel Til I Die
In all honesty, as far as performance is concerned, you'd likely be fine with a good set of rebuilt Brembo's. Braking is better than stock and less weight than the Akebono BBK. Don't get me wrong, the Akebono's look nice filling out the wheel and the stopping power is excellent, but I honestly doubt that any of us running them are using them to their full potential. I know I'm not. When I decided to change my brake setup from the single piston OEM on my '05, I found a good deal on the unused Akebono BBK which was a better price than the Brembo's that I found at that time. That was honestly the deciding factor for me.
Old Dec 11, 2025 | 09:26 AM
terrasmak's Avatar
Show or track use?
Old Dec 12, 2025 | 08:45 AM
iideadeyeii's Avatar
iideadeyeii
You get better fade resistance, but initial stopping with Stock vs Brembo vs BBK is negligible. There's a video on Youtube that tests all 3 on the same vehicle.
Old Dec 15, 2025 | 06:25 AM
ChocolateCowboy
Show or track use?
really just for show .... but I do spirit drive..
Tac-M
Dec 26, 2008 05:29 AM
Amiricanmade
Nov 26, 2007 05:31 AM
Changvi
Aug 23, 2007 07:13 AM
