Z32 (300ZX) Brakes on a 350Z?
Old May 4, 2006 | 01:04 PM
  #121
KNS Brakes's Avatar
KNS Brakes
Vendor - Former Vendor
The calipers are the same except for thickness - so clamping force will be the same.
But you want the thicker rotor because that is where you get the gain. More heat mass and better cooling.
Probably more than $500 once you roll in pads/lines/fluid with the rest but no where near $1300 which is the min for a BBK. Replacement parts should be very inexpensive also.
Old May 4, 2006 | 01:09 PM
  #122
Havok_RLS2's Avatar
Havok_RLS2
My numbers came up to $450.00 with everything you mentioned above + rear calipers. All the parts are very inexpensive and you can purchase re-manufacturered calipers from Advance auto for as little as $90 each.
Old May 4, 2006 | 01:11 PM
  #123
trescincuenta's Avatar
trescincuenta
Not to mention a million diff pads available for those z32 sumitomo calipers! I was runnign some Porterfield pads on mine when on the 240sx and man did they work great
Old May 4, 2006 | 01:18 PM
  #124
sfarrah's Avatar
sfarrah
[QUOTE=Havok_RLS2]I'm not sure. I woundn't think so but it's already been pointed out the anything over 300mm is pretty much pushing it. The only way to know for sure is to do a test fit.
If it does work then I'd have to say that about the largest you can go without have to alter the caliper in some way or another.
Anyone else have any thoughts on the matter?
QUOTE]
Z1 uses z32 calipers on 13inch mustang rotors for one of their upgrade kits for the z32 and I believe they machine the caliper a bit for proper fitment. SPL sells relocation brackets for using brembo 12.8 inch 350z rotors with the z32 calipers for upgrades for the z32's and used to sell brackets for the 12.8inch skyline rotors. These don't require the caliper to be machined, but a bit of the pad area overlaps the rotor and doesn't get used.
Old May 4, 2006 | 01:41 PM
  #125
Soundeffects's Avatar
Soundeffects
I agree with the Z32 30mm calipers WILL WORK on Brembo Z33 rotors...If it works for the 240sx crew then I know it will work for us. I think the brackets that are already out there wouldn't have to be changed too much to make this work anyhow.
Old May 4, 2006 | 02:01 PM
  #126
Havok_RLS2's Avatar
Havok_RLS2
Who currently make these brakets you're talking about.
Old May 4, 2006 | 02:04 PM
  #127
Havok_RLS2's Avatar
Havok_RLS2
[QUOTE=sfarrah]
QUOTE]
See... Thats what I thought too but since I couldn't find that information I didn't want to say anything. Thanks for the info.
Old May 4, 2006 | 02:48 PM
  #128
Havok_RLS2's Avatar
Havok_RLS2
Anyone got real good pricing on 12.79" brembo rotors? That might be the better direction to go sides staying with the non-brembos.
Old May 4, 2006 | 10:40 PM
  #129
KNS Brakes's Avatar
KNS Brakes
I've seen those kits - they still cost over $1000 by the time you are done - the Z1 kit is $750 without calipers ($90 + core charge each)
The SPL kit would be something like 200(brackets) + $350 (rotors - unless someone finally stopped robbing Brembo owners) + $250-300 (calipers - estimate) + pads/lines/fluid.
At that price I'd be thinking a lot about the $1300 or so Wilwood kits. Plus the large increase in rotor diameter is going to wack the bias pretty good.
It's definitely a tough project - ?? Please note I am NOT bashing the products they worked hard to produce - I'm simply stating MY opinion. I'm faced with the exact same problem on my car
Old May 5, 2006 | 09:37 PM
  #130
Havok_RLS2's Avatar
Havok_RLS2
Wow! Those prices seem really jacked up a bit. I happen to know for a fact that the bracket don't cost that much to make (like $50 for both at the most) and you can buy all four front and rear calipers for less than $250 from Advance Auto and Auto Zone after core exchange (they don't know or even care about the difference between the 300zx and 350z calipers). Lines? There are online sources that sell steel braided line kits for $50 or less on a few e-bay store I have come across.
Like I've been saying before... "This is NOT an alternative to a quality BBK. It should only be considered an UPGRADE from the crappy non-brembo stock system." If there are companies that are marketing these kits for more than $700 complete with everything including rotors. Shame on them.
I know I can do it for cheaper than that. Watch me.
I'd also like to add the Z1 is still developing their kit based on last known information in this very same thread. I'm not sure where you got the pricing quote of $750 because it's not even on there web site but I'm sure that if Z1 chimes in again they can clear this right up for us.
Old May 5, 2006 | 10:08 PM
  #131
KNS Brakes's Avatar
KNS Brakes
It's a different Z1 (Performance or Motorsports - get them confused) down in Atlanta that i referred to the $750 number. They sell brackets w/ 13" 2 piece rotors - can't recall if they include lines/pads whatever.
The calipers are extra - they sell those separately.
Old May 5, 2006 | 11:42 PM
  #132
Havok_RLS2's Avatar
Havok_RLS2
I think that the upgrade for the 300zx not the 350z. I saw that site too. I didn't see anything like that for the 350z. You got a link?
Old May 9, 2006 | 07:18 AM
  #133
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
brackets are alot more money than $50 to make as well...unless you are making thousands at a time.
Case in point, I just go through making a BBK for my '79 280ZX. Used AP 6 piston calipers, AP 14 inch rotors, and had brackets and hats for the rotors built as one off pieces. Let's just say and Endless kit for a 350Z is around the same $$ as I now have invested into the kit. The brackets and hats cost me nearly $1000 to have made (again as one off pieces).
The kit will surely be less than the $1300 level most entry level BBK's go for
Old May 10, 2006 | 08:25 AM
  #134
Havok_RLS2's Avatar
Havok_RLS2
Yes... But will it be less than $600 without the cost of calipers? I can have brakets cut for less than $50 if you wanna send me the specs. Might be able to get them even cheaper than that if you wanna do a bulk order.
Old Jun 27, 2006 | 07:12 PM
  #135
Morris's Avatar
Morris
Any update on this project, or update from Z1 Performance on their kit?
Old Jun 28, 2006 | 04:42 AM
  #136
Z1 Performance
Former Sponsor
we have been tied up on other things so have not done anything further as of yet
Old Jul 14, 2006 | 12:08 PM
  #137
trescincuenta
Has anyone seen how hard it would be to adapt the brakes from an STI to the 350z? The STI brembo's are larger than the 350z brembo's and complete sets of rotors and calipers front and rear for under $1000. Here is a full set for $900...
http://forums.nasioc.com/forums/show....php?t=1039936
A dude on zilvia.net successfuly adapted these brakes to his 240SX. Required a simple adapter for the front and the rear calipers bolted right up using 3mm washers as spacers for proper offset.
Old Jul 14, 2006 | 12:12 PM
  #138
BlackSpec02's Avatar
BlackSpec02
cool idea.
Old Jul 14, 2006 | 12:22 PM
  #139
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Stock Z32 Rotors are 280x30
Stock Z33 Rotors are 296x24 (or something like that)
Stock R32 GTR are 295x32
The R32 GTR may make more sense.... but only for the better thickness and the fact that you will have a 4 pot caliper...
The Caliper will bolt up to the OE Spindles but the offset of the caliper / rotor will rub slightly, so a spacer will have to be made for both the rotor and caliper...
IMHO: NOT WORTH IT! Better off keeping the OE brakes w/ better pads...
Now, putting the 350Z brembo's or Z32 / R32 brakes on a 240 thats another story... its more of an upgrade...
Old Jul 14, 2006 | 12:39 PM
  #140
trescincuenta
Jason i meant Subaru WRX STI brembo's on a Non Brembo Z car. It looks like they can be had for cheaper than Z brembos, and they are larger.
Or were you replying to someone else's post on this thread?
