Install ? Volk LE37 & Brake
Old Mar 8, 2004 | 09:30 AM
mel terrana's Avatar
mel terrana
Default Install ? Volk LE37 & Brake
Need some help, rec'd a great set of LE37s from ReHigh Online, Friday, installed the back 19/9.5s no problem. Then when I went to install the fronts, didn't fit the hub but bolt pattern perfect. Problem is the brake disc mounting bolt sticks out over 3/4" keeping the wheel from bolting up. Check the 17" stock wheel (I have a Basic Z) it's wheel hub has a pattern of holes where this bolt fits into. Surely this problem come up before. This is what I did temporarily, I unscrew and removed the bolt. My thoughts are the lug bolts would be sufficient to do the job. Everything, fits and rolls great. Purchased the whole setup wheels & Toyo T1s, 245F & 275R, mounted and balanced. Time from ordering to door step, 8 days and that is from Florida to Washington State.
Old Mar 8, 2004 | 01:48 PM
zzzya's Avatar
zzzya
That bolt I believe was put there to prevent the stock rear wheels from being mounted on the front of the car since there is a stagger front to back. You did as you should by removing it. It serves no other purpose.
Stevo Z
Oct 3, 2015 09:14 PM
