Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)
Old Mar 24, 2004 | 04:19 AM
ether's Avatar
ether
Default Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)
Wondering if the 14" stoptechs F+R and BBS LMs 18x9.0 +25mm offset (F+R) will clear without spacers.
Thanks
Old Mar 24, 2004 | 07:54 AM
Blownaway's Avatar
Blownaway
No they will not, LMS have the worst brake clearence of most rims...if you want BBS you will have to go with CH in that size or go 19s in RGR and RSGT
Old Mar 24, 2004 | 09:04 AM
DocofMind's Avatar
DocofMind
14" front and rear. 6 piston front and 4 piston rear.
Old Mar 24, 2004 | 11:03 AM
N1-R's Avatar
N1-R
whoah whoah whoah! Docofmind, can you post more pics of the LM rims and possibly a full pic of it with the car? I'm wanting to get these rims too but they weigh quite alot right? around 25lbs for 18x10?? Can you order them in bronze/gold spokes or no?
Old Mar 24, 2004 | 11:50 AM
DocofMind's Avatar
DocofMind
25 pounds for an 18 x 10 is not heavy for a 3 piece wheel
I will get you more pics soon. The car pictured above is actually an E46 M3. From what I remember my friend telling me, they are available with gold spokes.
Old Mar 24, 2004 | 12:59 PM
N1-R's Avatar
N1-R
thanks dude!
yeah but i have track wheels and it wouldn't seem reasonable for me to add 7lbs to each corner....
oh how i dream of the TE37Mag.....
ps: post some pics of the E46 M3 as well with those rims
Old Mar 24, 2004 | 01:46 PM
ether's Avatar
ether
many thanks for the information
Old Mar 24, 2004 | 02:45 PM
DZeckhausen's Avatar
DZeckhausen
Default Re: Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)
For a definitive answer, you can call Luke at Tire Rack. 888-541-1777 x362. Luke has all the StopTech and Brembo templates and measurements. I've found him to be the most big brake friendly representative there.
That being said, the others are correct in that there's no way the LM will clear these brakes. I don't think it even clears the stock brakes on the 350Z Track Model! However, the forged BBS RE in 18x8.5 (front) and 18x9.5 (rear) will easily clear even the Brembo 355mm x 32mm big brake kit.
BBS RE
Old Mar 25, 2004 | 04:46 AM
ether's Avatar
ether
are these BBS LMs? i think both are 19" wheels, curious how much more clearance the 14" stoptechs need beyond the stock brembos
Attached Thumbnails Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)-no1959_2.jpg
Old Mar 25, 2004 | 04:47 AM
ether's Avatar
ether
Attached Thumbnails Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)-no2362_1.jpg
Old Mar 25, 2004 | 05:23 AM
DZeckhausen
Those look like LM to me. The 19" size gives you some more breathing room for caliper clearance before the spokes start to curve back inward.
The additional clearance required for the 14" (355mm) StopTech kit vs. the 12.75" (324mm) factory Brembo kit is in two places:[list=1][*]The barrel of the wheel, since the caliper is at least 15mm further away from the hub.
[*]The back of the spokes where they often (depending on wheel type) begin to curve inward. Since the caliper is located further from the center of the hub, the spokes may interfere with the caliper face, near the top.[/list=1] Note that the StopTech caliper doesn't stick out significantly more than the Brembo factory caliper. It's just located further out from the hub, since the rotor is 31mm bigger diameter.
Old Mar 25, 2004 | 05:42 AM
ether's Avatar
ether
thanks for the analysis, great to have the info.
I'm looking to get a second set of 18" wheels for track, while although the LMs look great and are light, seems that I will probably have to go with another wheel for more clearance. Maybe some advan model 6's
Attached Thumbnails Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)-main.jpg
Old Mar 28, 2004 | 07:41 AM
ether's Avatar
ether
Default Re: Re: Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)
BBS RE
done more research on the RE wheel and i'm starting to get interested. I'm thinking of running 245s or 255s all around at the track, henceforth would want the same rims F&R. Do you know if the 18x8.5s will clear both the F&R 14" stoptechs.
thanks for pointing these wheels out, and here is my bad photoshop of how they would look on my Z
Attached Thumbnails Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)-re-web.jpg
Old Apr 9, 2004 | 03:53 AM
ether's Avatar
ether
Default Re: Re: Re: Will 14" Stoptechs clear BBS LM 18x9.0 +25mm (F+R)
just got reply from Luke @ www.tirerack.com
confirmed that the following will clear the 14" StopTechs F&R on the 350Z:
BBS RE TYPE 773 (front and rear): 18x8.5 +25 offset
BBS RE TYPE 774 (rear): 18x9.5 +25 offset
and that the following RS-GT will not
BBS RS-GT TYPE 952 (front and rear): 18x8.5 +25 offset
BBS RS-GT TYPE 923 (rear): 18x9.5 +25 offset
Wanted to add the information to the database.. many thanks tirerack
now just waiting to get confirmation whether the 18" SF-Winnings will also work to make the decision
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
