Konis are here!!!!
Originally posted by jmark
Redfoot,
Can't wait to hear your report. I'll be getting mine installed in May. Who will be first to give a Koni report?
Redfoot,
I'll post a report whether or not I'm the first to get it done
Cant wait to hear how they are!
So I take it this was just the pre-order Koni's that dwnshft had back from January right?
Is there any info on the when Koni's will be available for regular purchase? Even though www.shox.com advertises them, when i called a rep from the site, they actually are NOT available yet, and he did not even have a tentative release date
-drew
-drew
-drew
-drew
yes this was the preorder. got the whole package from 350EVO.com so I am using the Eibach Pro kit (lowered 1"). their purpose is indeed to take care of the bounce and to improve all around handling including the occasional track weekend use. I would guess that these would be in regular stock in the next month or so, but really, i don't have a clue
Originally posted by happypants
I plan to either have the shocks installed or do it myself, as soon as I get the shocks. I'm debating spending $175 to have the shocks installed vs. do it myself. Depends how lazy I am I guess...
Originally posted by Redfoot
lets see if this gets attached this time..
guess it doesn't like my photo...
Originally posted by Mr. Motion
Do you know if the car will need to be re-aligned after you install the struts? I know that some cars do but not sure about this one. Looks pretty simple as a DIY project.
I just got the shocks today. I was excited until I saw the outer box which contained the three shock packages was damaged, had a hole in one side. With trepidation, I opened it up to see how the shocks were packed.
All three Koni boxes were sealed with the original seals, but two of the three had puncture holes.
The two longer shock boxes both had holes in them caused by no materials to hold the shocks in place, thus letting the shocks roll around the boxes. Both shocks have a part of the shock on the tube that was bent, looks like a bracket to hold brake lines or some other type of cable. The shocks tubes aren't leaking. Some of the paint is chipped off one of the shocks.
The other box, which holds two struts, wasn't damaged, but the styrofoam used to hold the top ends of the struts was nowhere near enough to hold them in place. And the cardboard inside the box to hold the tubes was also smashed.
Essentially, this would be like buying a part off of ebay and the part just thrown in the box with no padding. What a **** poor job of protecting these shocks!! I plan to let Koni know about this, pretty sad considering their history.
I got photos, which will be sending to BJZ soon. I'm not blaming 350EVO for this, just UPS and Koni.
Some other people have documented the shock/strut replacement. It looks pretty easy.
Yea the packaging sucks. Koni should be shot for such a **** poor job. Nothing bent/broken, just missing paint. The brackets on the side of the front set are supposed to be at an angle. Sat down today to try to figure out initial settings, I'm not one for reading to many instructions but all there is are pictograms, I'll be damned if they make much sense to me, and I'm Dutch.
As far as an alignment goes I'll drive it for a short while and see how things go, but it will be done in the near future.
Eric Hu eric@esports.com has a tracking number for the Koni's coming out Atlanta ..
We hope to have a Set on one of the Test Mules by this Weekend.
Of the five set's I think Eric has two sets for California not purchased..
I'll go with my Installer... Heh ! to install full soft..
Cheers Amy
Cheers Amy
Who will have the Konis installed first????? My money is on Boomer or Amy.
