Firmer suspension in Track model?
Old Sep 26, 2002 | 09:14 PM
beagle249's Avatar
beagle249
Default Firmer suspension in Track model?
Is it true that the Track model has "tighter" suspension than the other Z models? The Nissan website does not differentiate between the models as far as suspension goes, but a Nissan salesman told me the Track does have a firmer suspension.
I test drove a Touring model w/auto and found the ride to be fairly harsh going down Freeway 101 in the Bay Area, but I am used to the suspension in my Integra GS-R (which isn't exactly like riding on air either).
Old Sep 27, 2002 | 04:52 AM
ethan84ae's Avatar
ethan84ae
Charter Member #35
All of the cars have the same suspension tuning. Variation in ride harshness can be attributed to different tire sizes / profiles between the models.
Ethan
Old Sep 27, 2002 | 04:56 AM
Z33's Avatar
Z33
Suspensions are the same, from Base to Track. Since the Brembos are somewhat heavier than the stock brakes, even the Rays only result in comparable unsprung weight numbers, no better than the rest.
You can probably detect a difference between heavier and lighter models, maybe even between 17" and 18" wheels, but Nissan made the suspensions consistent on purpose. You can dial in all the difference you want with aftermarket components.
Z33 - Silverstone/Touring/6MT w/Aero&Nav
Old Sep 27, 2002 | 03:05 PM
dwnshift's Avatar
dwnshift
From what I have heard and seen, the track model has some additional bracing that the others dont have. Most of these braces are underneath the car, and beneath the carpet on the interior. Check out the pictures under the modifications section on the gutted 350ZR.
Old Oct 2, 2002 | 07:03 AM
mydogscool's Avatar
mydogscool
Brochure, and pictures show underbody air diffusers on the Track model. See nice picture of Track underbody at strictlyz.com.
Old Oct 2, 2002 | 08:29 AM
Z33's Avatar
Z33
Underbody diffuser(s) are already available here:
http://www.japanparts.com/NissanPart...dyZ33/Aero.htm
Z33
Old Oct 2, 2002 | 09:16 AM
j's350z's Avatar
j's350z
those are not the underbody difusers that they are talking about. Those are ground effect pieces that nismo makes. The track model has plastic like cladding under the body that you don't see...
Jason
Old Oct 2, 2002 | 10:49 AM
Z33's Avatar
Z33
j's350z,
Ah. That would be #6 on the SCC pic?
http://www.sportcompactcarweb.com/fe...cc_350znissan/
My Touring seems to have everything else. I thought it was missing the muffler air-dam and figured that was JP part, but I just checked and it has that already. I can't see #6 on my Z.
Z33
Old Oct 2, 2002 | 11:43 AM
mydogscool's Avatar
mydogscool
Correct. #6 is not on your Z because you have touring. I do not know if this peice is available aftermarket. I think the track has a couple other small deflectors scattered about.
Old Oct 3, 2002 | 04:11 AM
j's350z's Avatar
j's350z
every car should have #6 on their car. That was an enthusiast model that they tested, not a track.....
Jason
NJ
Old Oct 3, 2002 | 04:37 AM
Z33's Avatar
Z33
Bugger. So we still don't know what we're talking about WRT Track-only diffusers (my Z's got undercoat, so my #6 is a stealthy black). Gotta be a diffuser pic somewhere.....
