New Rotors just for looks?
Old Apr 10, 2004 | 05:16 AM
silverstoneTT's Avatar
silverstoneTT
Default New Rotors just for looks?
My question is this: Does anyone know of rotors that look better than the stock, like drilled, that don't cost a ton?
Im not interested in a big brake kit because I never track the car so I dont need huge brakes, I just want nicer looking rotors.
Thanks
Old Apr 10, 2004 | 06:28 AM
KornerCarver's Avatar
KornerCarver
EBC rotors. You can get them from Tire Rack.
Old Apr 10, 2004 | 06:35 AM
bigdaddy's Avatar
bigdaddy
check out carbotech's rotors too. they are slotted and inexpensive, $99 a pair for the fronts and $89 for the rear if i remember correctly.
http://www.carbotecheng.com/main.htm
Old Apr 10, 2004 | 09:20 AM
silverstoneTT
Thanks, for the links.
Old Apr 10, 2004 | 09:24 AM
peptidbond's Avatar
peptidbond
They will be more functional than just looks to. Aftermarket rotors are normally cadmium coated inside and out. So, the hub and inner veins will not rust. This should help to keep your rims a little cleaner too. Now the braking surface will rust a little, but that is normal. Good luck with the rotors.
Old Apr 13, 2004 | 09:11 PM
mgl's Avatar
mgl
how much did you get those rotors for?
Old Apr 13, 2004 | 09:34 PM
Cyp's Avatar
Cyp
Where can you purchase stock brembo brakes that are on a track model to put on an enthusiast?
Old Apr 13, 2004 | 10:42 PM
ssk0771's Avatar
ssk0771
Default Re: New Rotors just for looks?
Thanks
I got Rotera. They are slotted but not drilled. I heard that drilled rotors have tendancy to crack under extream heat/pressure.
They are very good quality. The guy at Rotera told me that they are also MADE HERE IN THE USA.
wicked4u2c (forum member) helped me get these rotors.
Why don't you PM him.
Just click here.
http://www.my350z.com/forum/private....ge&userid=7939
OR
www.pmpdesigns.com
You can also get Stop Tech Rotors from Performance Nissan.
http://www.performancenissanparts.co...55502e58597b54
Old Apr 13, 2004 | 10:56 PM
DruDragzOn's Avatar
DruDragzOn
They're extremely expensive brand new. You can get better brakes for less money by buying other brands. Or you can go to the private classifieds and get lucky. Sometimes track owners sell their brembos setup to upgrade to aftermarket brakes. They're usually snatched up pretty quickly though.
Old Apr 14, 2004 | 07:25 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Do they make the EBC ones pictured above that fit the Brembo system? I couldn't find them on tirerack.
Old Apr 14, 2004 | 08:32 PM
Cyp's Avatar
Cyp
DruDragzOn;
thank you for the reply.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
