Just installed RSR springs
Old Apr 19, 2004 | 04:39 PM
hfm's Avatar
hfm
Originally posted by zxsaint
wow dan... losing 20-40lb on a spring swap is pretty significant (and cool!).
Woah! That's not per spring. That's my guess total. I can only say I held the RSRs then held the stock and the stock felt significantly heavier. So, I'm thinking 10 + or - a few pounds.
Old Apr 19, 2004 | 05:08 PM
zzzya's Avatar
zzzya
I would agree with HFM on all accounts. I did notice that the springs took 2-3 weeks before they really settled. I love the drop I obtained. I was looking for something with a subtle drop so I could still drive around without smashing up my front end and so far I have not had any issues with clearance with these springs. The ride really seems to have improved over the past month with great reduction in bounce yet a very linear feel in cornering, no suprises. There is still some bounce and Konis will be needed if you want it completely gone.
Old Apr 30, 2004 | 11:37 AM
johnnyblaze's Avatar
johnnyblaze
I've had my RSR's on my car for about 4 months now, the bouncy rear end effect is gone. It took the springs about 1-2 weeks to finally settle the front and about 2 weeks for the rears to finally settle. Once it settles you will be able to notice the drop alot more. The Z definitely feels more responsive and aggressive with these springs.
Old Apr 30, 2004 | 01:38 PM
myinfinitig20's Avatar
myinfinitig20
whats the price difference between the rsr and the rsr titanium? any good vendors out there?
Old Apr 30, 2004 | 01:55 PM
VR3's Avatar
VR3
Any squeaks ?
Old Apr 30, 2004 | 02:52 PM
LATEZ's Avatar
LATEZ
I have eibach too heard too many problems with the tein and sagging issues
Old Apr 30, 2004 | 05:49 PM
johnnyblaze
I haven't heard a squeak yet, mostly from my rear hatch so i dont think its the springs :P
Old Apr 30, 2004 | 07:25 PM
D@ActiveTuning's Avatar
D@ActiveTuning
No squeeks on the RSR's yet...
Old May 1, 2004 | 07:10 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
D - did you see pics of my car with the RSR's - trust me, the drop is damn near perfect once settled
Old May 1, 2004 | 06:44 PM
D@ActiveTuning
Yeah I did, but can you post it or link it again, I want to compare to how mine looks now. It's been about 2 weeks now. I'll post pics of mine once I see yours again, and we'll see how they look.
Old Jun 16, 2004 | 09:35 PM
ZZtopp's Avatar
ZZtopp
How do the spring rates of the RSR's compare to stock? Anyone tried these with the Koni's yet?
Old Jun 17, 2004 | 06:45 AM
Gsedan35's Avatar
Gsedan35
RSR 350Z
Front:345 Rear:417 F+10% R+22%
Transfers 12% roll stiffness to rear
Old Jun 17, 2004 | 07:42 AM
ZZtopp's Avatar
ZZtopp
Originally posted by Gsedan35
RSR 350Z
Thanks for the info, but I thought stock springs were 347 front, and 419 rear. This would make the RSR's almost exactly the same. Why the 10% and 22% increases?
Old Jun 17, 2004 | 10:58 AM
Gsedan35's Avatar
Gsedan35
I'm the source for the 347/419 oem data, that data was in error, I did a post some time ago explaining things(the old data keeps cropping up however) and that the corrected oem rates are 314/342. Of note is the fact that Hotchkis says oem rates are 310/350, we are close enough to confirm each other, normal +or- coil spring rate tester error explains the slight difference between my rate info and theirs.
345/417 = +10%/+22% vs oem of 314/342
Old Jun 17, 2004 | 11:15 AM
ZZtopp's Avatar
ZZtopp
Thanks for the clarification.
It's interesting that springs with higher rates have been reviewed by most as improving the ride quality. Now I'm totally confused as to which springs would be the best choice for the Konis I'm going to install in a couple of weeks. My goal is to improve ride quality, and since the Konis were designed to work with OEM springs, perhaps those may be my best choice, although I did want to drop the car a bit. (.6-.75).
Old Jun 17, 2004 | 01:23 PM
adanande's Avatar
adanande
If you are going to get way bars or shocks after you get you springs i recomend you wait on the spring install and install them all at once. This will help your springs settle differently than without aking this precaution. If you have to unlaod your prings( take them off) they will never extent back to teir original out of the box elasticity and they also are more compressd naturally because they have settles. If you put them back on they are already maxed out on their compression/settling tso they wont ever settle again giving you bounce and slippidy sliding feeling instead of that miraculous stick we are so used too. I recoment the entire setup be all at once and tuned. if you plan on getting new springs after your stock shocks wearand keep the stock sways then by all means go ahead.peace just experienced many problems with suspension mishaps in the past.
Old Jun 17, 2004 | 01:34 PM
ZZtopp's Avatar
ZZtopp
I am installing Konis in a couple of weeks. The question is whether or not I'm going to change out the OEM springs to something else during this install.......some springs that might give me small a drop, improve the ride, and work well with the Konis..
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
