dissapointed with eibach drop
Old Jun 11, 2004 | 10:49 AM
mickey's Avatar
mickey
Got 200+ miles on the Eibach Pro kit, it definitely require usage to settle these springs, but I also noticed my rear-right is not dropping as much as others, wonder what could be the cause?
My rear camber is quite extreme on the negative side " // \\". I have an appointment for alignment service this Saturday, hopefully that will minimize the negative camber.
Rgd,
Mickey
Old Jun 11, 2004 | 10:58 AM
JimRHIT's Avatar
JimRHIT
not likely .... you need adjustable rear camber kit from Kinetix or someone else ... brings that nice $180 drop up to at least $500 plus install and alignment ... thats why I sold mine
Old Jun 14, 2004 | 06:00 AM
mickey's Avatar
mickey
Default Alignment helped with extreme negative camber
Got my alignment done this past weekend, my rear alignment result:
Rear Left:
Before alignment = -2.8 for camber, 0.21 for toe
After alignment = -1.9 for camber, 0.02 for toe
Rear Right:
Before alignment = -2.9 for camber, 0.27 for toe
After alignment = -2.0 for camber, 0.01 for toe
** Front camber not adjustable **
Negative camber is now minor compare to before alignment, which was too much.
Rgd,
Mickey
Old Jun 14, 2004 | 06:59 AM
SEzzz's Avatar
SEzzz
that will stil eat the tires really badly won't it?
Old Jun 14, 2004 | 08:52 AM
mickey's Avatar
mickey
Don't know about 'really bad', but it certainly is better than before alignment, it is now within the specification range. I like the drop look so much, I think I will keep the spring as well as keep changing tires if need to.
Old Jun 14, 2004 | 09:24 AM
JimRHIT's Avatar
JimRHIT
the camber will only sacrafice about 10% of the tire life ... it is the toe that will just chew up the tires really bad .. and you got that under control now
Old Jun 14, 2004 | 05:25 PM
ThreeFitty's Avatar
ThreeFitty
My car was in the Eibach booth at SEMA in NJ. They also have a camber kit, I will give a report when I recieve mine.
Old Jun 15, 2004 | 12:00 AM
Beaker02's Avatar
Beaker02
Mine took a good 6 months to fully settle. As far as tire ware, I'm at 30K (springs went on at 19K) Will be getting new tires in the next 10K. Very loud at this point but tread ware in minimal. Just feathering.
Old Jun 15, 2004 | 07:12 PM
kosta157's Avatar
kosta157
i have about 1,000 miles on mine with my 19's and i am getting no wear, could it be i don't drive the car much? also mine settled in very nice. i will post a pic
Old Jun 15, 2004 | 07:14 PM
kosta157's Avatar
kosta157
Old Jun 15, 2004 | 11:45 PM
SEzzz's Avatar
SEzzz
b-e-a-u-t-i-f-u-l
props man
Old Jun 16, 2004 | 06:49 AM
toykilla's Avatar
toykilla
i thought the drop was perfect on mine.. more and the wheels dont look right.
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
