Help - Brakes issue on 2003 touring
my Z is at 20K miles and i ve to replace to front rotors ?????
is this normal?????
240$ for front rotors and 475$ total for front brakes job???
anyone had brakes problem on Z
HELPPPPPPPPPPPPP
is this normal?????
HELPPPPPPPPPPPPP
I replaced my front rotors with AP Big Brakes but my rear rotors are SHOT, this with only 15k miles!!!!
The squeak so loud right now that it is embarrasing to roll up to a stop light....It is bad when people are turning their heads and covering their ears because the noise is sooooo bad!
Brakes are garbage...I am going to have my rear brakes replaced ASAP, I will probably go with a OEM sized upgrade....
I had my front rotors and pads replaced by dealer at 12k miles under warrenty.....forgot to mention that....
I still ripped them off and put on the big brakes...makes a huge difference with the SS brake lines as well.
I agree with complaining, but they KNOW the brakes are garbage
just hit 19k and my brakes are messed up.. first was highpitched for a little bit now sounds like somebody is rubbing rusted metal on my car..
i'm not much of a car guy.. what should i do?
where to replace? dealer? some shop? and what breaks to get?
thnx
thnx
Guys,
Wear rates on brakes vary tremendously depending on usage. The base model brakes are perfectly fine for everyday driving, and are actually much better than many other sports cars out there. They don't hold up to competition use, but they're fine for street driving.
As for squeaking noises, you need to rebed your pads and rotors. Do a search on bedding brakes and you should find some answers. Also, do a product search on www.stoptech.com for a stage I and II upgrade. We have some great packages on rotors, lines, pads, fluid, etc. You can buy these packages from any of our authorized resellers.
