will aftermarket suspension resolve feathering
Old Aug 29, 2004 | 12:51 PM
350ZTN's Avatar
350ZTN
Default will aftermarket suspension resolve feathering
As the subject reads is there an aftermarket suspension kit such as the Nismo s-tune that will remedy the tire feathering problems of a 2003 model?
Old Aug 29, 2004 | 02:49 PM
ksj's Avatar
ksj
I don't know if it resolves the problem as I never had it but I installed the s-tune on my 2003 about 13K miles ago (after 4k with stock suspension) and haven't seen any issues. I also have the LM-GT4 wheels which I put on around the same time as well.
Old Sep 10, 2004 | 03:33 PM
350ZTN's Avatar
350ZTN
does that suspension let you adjust the caster camber? if so what are the specs you put it at?
Old Sep 10, 2004 | 09:38 PM
DragonGcoupe's Avatar
DragonGcoupe
Bump*
I plan on installing Tein Flex w/ EDFC if I get a 350Z (probably 2004.5). I was wondering if this would relieve me of feathering?
Old Sep 11, 2004 | 02:03 AM
CaptinB's Avatar
CaptinB
2004.5 should not have the feathering issue. It's VERY rare on the 2004's much less the 2004.5's.
CaptinB
Old Sep 12, 2004 | 02:14 PM
350ZTN's Avatar
350ZTN
those of you that have an aftermarket suspension where you can adjust the caster/camber are you having feathering issues still, what are the specs you put the caster/camber to?
Old Sep 12, 2004 | 07:58 PM
Chicken's Avatar
Chicken
CaptinB
This may only be due to the fact that 2003 owners have had their cars longer and driven more miles. Give it time, but I hope you're right.
Old Sep 13, 2004 | 06:45 PM
350ZTN's Avatar
350ZTN
Default bump
bump for an answer to my question about the 2003's...I don't need to know about 2004 or 2004.5, I need to know obout the 2003's
Old Sep 14, 2004 | 07:36 AM
kgb's Avatar
kgb
Default Re: bump
I have the Tein basics on my 2003 and I still have the feathering problem.
Old Sep 14, 2004 | 08:39 AM
DmitryZ's Avatar
DmitryZ
Default Re: Re: bump
I have a 2003 with a feathering problem. In my experience the feathering issues are directly proportional the dealership alignment machine and their ability to use it. After screaming and yelling at my incompetent dealer I took my car to another dealership with one of those light/laser alignment machines and competent mechanics. They did the alignment EXACTLY according to the TSB and 5000 miles later my tires don't even look worn.
Dmitry
Depravity
Oct 1, 2015 04:49 PM
SharX59
Sep 27, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
