Eibach Springs
Old Sep 1, 2004 | 12:27 PM
blu3design's Avatar
blu3design
Question Eibach Springs
Looking to order the Eiback Pro-Kit and want to be sure they will work with factory shocks...If I must order new shocks, how do you fell about the Koni 3-way adjustable...I am not looking for the coil-over setup, just a daily driving, well handling setup...H&R springs?
thanks for the help,
aAron- Atlanta - USA
Old Sep 1, 2004 | 01:28 PM
myz8a4re's Avatar
myz8a4re
hey aaron, i have the eibach prokit springs & am very happy with the results from them. the factory shocks work very well with these springs. i think the factory shocks/struts are very good on the z. i use them in conjunction with the front/rear camber kits & rear traction arms to get the best alignment specs possible...that call is yours. the eibach has a very nice drop w/o slamming it & is very noticeable. the progressive spring rate also alieviates the bounce that the z is well known for. makes for a smoother ride while still tightening things up in the corners when loaded. best of both worlds really....cant beat 'em IMO..............best of luck!
-justin
Old Sep 1, 2004 | 01:41 PM
blu3design's Avatar
blu3design
-justin
thanks for the info, sounds like a great move, i will place the order soon...
aA-
Old Sep 1, 2004 | 02:05 PM
myz8a4re's Avatar
myz8a4re
anytime, good luck aaron!
-justin
Old Sep 1, 2004 | 02:21 PM
G352NV's Avatar
G352NV
I have a used set with 3000 miles on them 150.00
Old Sep 1, 2004 | 03:20 PM
RNL323's Avatar
RNL323
Mod My Ride
Default Re: Eibach Springs
My Eibachs were put on last weekend. Not sure if you got the 17s or 18s but you can check out mine below. The ride is definitely stiffer/less bounce and the drop is only about an inch but the inch makes a HUGE difference appearance wise because you will fill out the well more...
Old Sep 1, 2004 | 04:26 PM
onii's Avatar
onii
i cant wait to get mine...the back gap with my 19s is buggin the hell outta me
Old Sep 1, 2004 | 07:26 PM
350Zteve's Avatar
350Zteve
They work just fine with the stock shocks. The spring rates are very close to stock, so they won't over tax the shocks. I'm very happy with my Eibachs.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
