removing sways is IMPOSSIBLE?!?! help!!
Old Sep 19, 2004 | 02:49 PM
autois4pussies's Avatar
autois4pussies
Default removing sways is IMPOSSIBLE?!?! help!!
Hey guys im having a great deal of trouble and i was wondering if i can get some help. Im trying to put on my sways but im having a hell of a time taking off the stock ones. Im working on the front and I was able to take off the endlinks with great difficulty but the bracket screws just wont budge. Ive even used wd-40. Can you guys help me out??
If i cant get them off then ill have to spend an extra $100 for what should have been a relatively easy install.
thanks for the help guys
Old Sep 19, 2004 | 03:15 PM
MIAPLAYA's Avatar
MIAPLAYA
Default Re: removing sways is IMPOSSIBLE?!?! help!!
Get a breaker bar....
Old Sep 19, 2004 | 04:58 PM
autois4pussies
its sunday and stuff is closed... plus i gota go back down to UCSD tomorrow so i wont be able to buy it
any other way??
thx for that though
Old Sep 20, 2004 | 10:12 AM
dkmura's Avatar
dkmura
General & DIY Moderator
I had the same problem and had to resort to taking off my jack handle and putting it over the handle of my 1/2" drive wrench to provide enough leverage to remove two of the bolts holding the front brackets on. You'll need two people to do this: one to hold the jack handle and the other to hold the wrench/socket onto the recalcient bolt! Use an impact socket for this one, if you have a set.
Interestingly enough, the FSM suggests that these bolts be torqued to something like 65 ft/lbs. (my memory is a bit hazy on the exact # since this was over a year ago), I suspect that liability concerns had Nissan torquing these puppies to something like 450 ft/lbs or more. Those bolts will NEVER come off if the owner doesn't do any maintenance or upgrading...
Old Sep 20, 2004 | 01:11 PM
dnguyent's Avatar
dnguyent
I used a 1" dia stainless steel pipe x 16" long sleeved over my 1/2" socket wrench. Those bolts were a ***** to remove!
Old Sep 20, 2004 | 01:22 PM
MIAPLAYA's Avatar
MIAPLAYA
18" Breaker pwns jooh....
Old Sep 20, 2004 | 01:43 PM
mrZ's Avatar
mrZ
use a long pipe. get the car as high as you can to give you more room for the pipe. its a pain in the a#$. make sure not to try to remove the 5th middle bolt like i did. duhh.... be carefull threading them in too. i seemed to start another thread on 2 of the bolts. must have started them at a bit of angle or something. had to just keep going though and force it all the way.
Old Sep 20, 2004 | 02:01 PM
autois4pussies
thanks guys ill try that
Old Sep 20, 2004 | 10:25 PM
murrman100's Avatar
murrman100
If you continue to do mods to you car on your own, you may want to consider investing in a small/medium air compressor and tools. It will pay for itself after just a few mods.
I did it and it saves me a lot of time and money.
It will make all your neigbors think that you're rebuilding you engine.
Old Sep 21, 2004 | 03:57 AM
Sz28r's Avatar
Sz28r
If the bolts are that tight (stretched) - is it safe to re-use them or should they be replaced?
Old Sep 21, 2004 | 09:03 AM
murrman100's Avatar
murrman100
If you cross threaded them or stripped the heads, then replace them otherwise they should be fine.
Old Sep 21, 2004 | 07:29 PM
PhoenixINX's Avatar
PhoenixINX
airtools ownz all of you.
Old Sep 22, 2004 | 12:12 PM
autois4pussies
whats the cheapest ones cost?? They are pretty expensive arent they? Where is the cheapest place i can buy them?
thx for the help
and ya air tools do own
Old Sep 22, 2004 | 12:36 PM
murrman100's Avatar
murrman100
Kragen Auto parts
www.kragen.com
http://www.partsamerica.com/PartDeta...goryCode=3483A
This is the compressor that I have and it does a good job.
Its not the best but it did take the bolts off my sway bars and everything else that I've done.
Old Sep 22, 2004 | 01:13 PM
axxizzer's Avatar
axxizzer
agh, glad I got mine professionally installed, sounds really hard, Um...What sways are you replacing them with??
I agree with the breaker bar idea
Old Sep 22, 2004 | 01:20 PM
murrman100's Avatar
murrman100
They really are hard at all. The front bar was a piece of cake. Took me about 1/2 hour. The rear was a little bit of a pain but it was because I had to drop a section of my Borla exhaust out to get the bar installed.
On the scale of 1 to 10, it was a 2.
Headers rate a 6.
Cai rates a 1.
hulkout
Apr 28, 2017 09:00 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
