Wilwood Clicking noise, Help
Old Sep 28, 2004 | 05:09 AM
lanzzor's Avatar
lanzzor
Default Wilwood Clicking noise, Help
I have the 14 inch front wilwood kit with the 6 piston caliper. It sounds like the pads are clicking when your foot is off the brake. Once applied, the noise is gone. Any ideas?
Old Sep 28, 2004 | 10:41 AM
ADMAN's Avatar
ADMAN
Does it still do it when the wheel is off too???
Might just be hitting a wheel weight, believe it or not.
Old Sep 28, 2004 | 12:23 PM
lanzzor's Avatar
lanzzor
Just does it a low speed, does not happen when above 40-50 mph or when the brake is pressed.
Old Sep 28, 2004 | 07:06 PM
C Ray Z's Avatar
C Ray Z
Default I have the Wilwood and rotors
I had a click that turned out to be the fit of the rotor hitting at only one spot on the radius of the caliper due to adjustment. You might check to see you have .050 minimum clearance in the diameter of the rotor and the iD of the calipers.
Just my two cents.
If you have not had them on the track you are in for a great thrill. I just love mine on the track. You can go soo deep before breaking. I am still adjusting to the increased grip.
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
