Koni Shocks?
Old Nov 18, 2004 | 01:07 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Anyone with the Koni and S-Tech combo have a short review or impression they could post?
Looks like we may have enough interest for a group buy... BoosTed?
Old Nov 18, 2004 | 05:56 PM
kbirdsong's Avatar
kbirdsong
Originally posted by jjellyneck
So...what ride and handling qualities do you notice betweeen the coupe and roadster? You're implying that the roadster (later build that you have) is noticeably better in ride and possible handling. Thanks.
My coupe is a 2003 and the suspension then was harsher and had more bounce. That is what i am looking to fix.
Old Nov 19, 2004 | 05:37 AM
jjellyneck's Avatar
jjellyneck
Ah, makes sense. Stiffer dampers, properly matched to the springs will eliminate the bounce and poor handling over rough roads. Also help the ride somewhat.
Old Nov 19, 2004 | 09:02 AM
arizzee's Avatar
arizzee
Koni shocks and RSR springs have solved the bounce for me. Now when I drive I don't even think about the suspension anymore. Before all I could think about was the ******* bounce (couldn't enjoy the ride).
So...I recommend this setup but I'm sure that other springs will work also. Believe that the Konis are the key ingredient
Old Nov 19, 2004 | 11:43 AM
The Brickyard Rat's Avatar
The Brickyard Rat
I'm fine with the Z ride on NorCali roads but my wife is not. She notices every little bump in the road. Will the Koni's reduce/eliminate the harshness over bumps; i.e. result in a smoother ride?
Old Nov 19, 2004 | 12:28 PM
spn350z's Avatar
spn350z
Originally posted by Gsedan35
Ahhh, theirs a good reason for the differance.
Your roadster rides on a revised suspension that debuted on the roadster and made it to 2004 coupes built after 10/31/03. The revision was done to improve the ride quality of the Z. You can either locate a used revised 2004 suspension (I have the shock parts numbers on hand so you won't run the risk of buying a unrevised 04 setup). Or you could buy Koni shocks or Tokico D-specs and accomplish pretty much the same thing.
If you can, could you post the part numbers?
Old Nov 19, 2004 | 05:25 PM
xziteme's Avatar
xziteme
Most Definitely! Before I had the Koni's, my wife wouldn't even try putting on her makeup while riding in the car. With the Koni's she has no qualms about putting her makeup on while riding in the car.
Old Nov 19, 2004 | 09:50 PM
The Brickyard Rat
LOL!!
Thats high praise, xziteme!
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Nihsnek
Feb 9, 2016 12:57 AM
Paul.
Oct 16, 2015 07:34 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Suffolk350z
Sep 13, 2015 02:43 PM
