Buying/Leasing 350Z/370Z Purchasing Info
Question on oil change...
Old Oct 27, 2006 | 02:52 AM
andee's Avatar
andee
Default Question on oil change...
being new here i may have this in the wrong forum..will gladly take help on where to post.
my question is about oil changes..(350Z 2005 with 30,000miles) ..go to valvoline or nissan? every 3,000? . ..any advice on this? . thanks andee
Old Oct 27, 2006 | 03:34 AM
zand02max's Avatar
zand02max
Search the Forums, lots of useful information. Can't go wrong with any brand name oil, the interval is what counts! Filters, now thats another issue. Stick with the OEM filter and change every 3K!
Old Oct 27, 2006 | 11:12 AM
mg350ZR's Avatar
mg350ZR
...go to valvoline or nissan? every 3,000? . ..any advice on this? . thanks andee
DIY every 5K
Old Oct 27, 2006 | 11:54 AM
bailey bill's Avatar
bailey bill
Owner's Manual and Maintenance Guide say 5w-30 (API Service Grade SL) every 7500 miles.
bill
Old Oct 27, 2006 | 12:37 PM
HARRYPOTTER's Avatar
HARRYPOTTER
OMG...listen if you have fully synthetic Oil then you can change it every 4,000 to 7,500 miles...if you have regular oil then I would recommend changing the oil every 3,000 -4,500 miles...the filter...I agree stick with the Nissan OEM one. it really doesn't matter where you go to get your oil changed, but make sure you pick the oil you want and STICK WITH IT....mixing oils is not a good idea, because some companies use different detergents and when you mix the oils those detergents may be of no use anymore meaning the protection they would have provided before....they now won't provide.
(take it from a mechanic) but Zand02max is telling you good info...and learn to do it yourself...it's very simple, and you will feel good knowing that you don't have to pay for it. (But make sure you let a mechanic teach you, or just read up on it...there are certain steps that you must take (like not overtightening the filter, and oiling the rubber seal on the filter.
Ejoy,
Potter
BRS
Old Oct 27, 2006 | 02:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Mixing oils doesn't hurt anything, read up on bobistheoilguy forums for more info.
True, some oils have better additive packages than others. But that doesn't mean you can't switch around...
Old Oct 28, 2006 | 08:13 AM
andee's Avatar
andee
Ejoy,
Potter
BRS
wish i could do it myself but i happen to be female..dont laugh. .btw thanx for all this info, realize i shudda gone to past posts for all this..no manual so i'm pretty much in limbo till i get one. thanks again guys...andee
Old Oct 28, 2006 | 12:25 PM
no manual
Download a manual at Courtesy Nissan.
Old Oct 30, 2006 | 07:35 PM
Swiffer's Avatar
Swiffer
+1. Stick with the stock filter.
Old Oct 31, 2006 | 08:19 AM
HARRYPOTTER
mixing oil doesn't hurt anything?....you must be crazy...swapping oils may not hurt anything, but mixing oil DOES...Don't even tell me it doesn't
Old Oct 31, 2006 | 09:57 AM
Tayzzer22's Avatar
Tayzzer22
If I change the oil every 7500 (using amsoil rated for 7500), do I still have to change the filter every 3000-5000? Is this even possible to do without all the oil falling out?
burglapfd
Dec 6, 2020 01:04 PM
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
