Buying/Leasing 350Z/370Z Purchasing Info
Help With My 350z
Old May 9, 2010 | 01:21 PM
BxPrettiBoii's Avatar
BxPrettiBoii
Default Help With My 350z
My Alarm And Horn Just Stoped Working.. i Dont No Why i Was Told It May Be The Fuse. Where is The fuse located? and how do i tell if it is burnt out. I Did ry Holding The lock and unlock but it didnt work.
Old May 9, 2010 | 02:54 PM
350junkie's Avatar
350junkie
the fuse should be next to the pedals inside the car. There's a little insert that clips in there that you can take out. On the back of it there is a diagram that tells you what every fuse is for. Pull the appropriate one out, and look at it. There should be a piece of metal running through the clear plastic that is not broken. If not then it's blown. If you're confused compare it to another fuse in the grid.
Also if it's not down there, there is another fuse box under the hood next to the battery. Same deal applies there.
Old May 9, 2010 | 03:30 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
If You Don't Know How To Locate And/Or Identify A Blown Fuse, I Suggest You Find Someone To Help You...In Person.
Old May 9, 2010 | 04:03 PM
Guilty1s's Avatar
Guilty1s
Not sure where the fuse is... but there is a bitchin 3rd fuse box behind the battery under the cowl
Old May 9, 2010 | 08:06 PM
Are you looking at buying or leasing a 350Z?
Old May 9, 2010 | 09:15 PM
350junkie's Avatar
350junkie
^^lul
just noticed...
try for a 14% APR with a 10,000 down payment.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
