Drying tips?
Old Feb 13, 2005 | 04:36 PM
Art Vandaleigh's Avatar
Art Vandaleigh
Default Drying tips?
I'd like some of your opinions on drying the Z after washing. Has anyone used the california water blade with any success? My car is SB, so as you all know black is a bastard to keep clean and dry without getting flint and whatnot all over it after wiping it down. I've heard a few guys say they use leaf blowers to dry also? Whatever gets the job done quickly without going through a bunch of towels is what im looking for.
Old Feb 13, 2005 | 04:39 PM
zand02max's Avatar
zand02max
Water Blade is awesome, does not get in the cracks, but works well.
Old Feb 13, 2005 | 06:46 PM
DavesZ#3's Avatar
DavesZ#3
If you use the sheeting trick, most of the water will run off of your car. Then all it takes is a good waffle-weave microfiber towel to absorb the few remaining drops. Combine that with a leaf blower to get the water from all the cracks and crevices that it hides in.
Old Feb 14, 2005 | 05:29 AM
SungNamZ's Avatar
SungNamZ
Waffle Weave towels from: www.pakshak.com and "NIKOTA" Item Number: 01239 160 mph electric Car and Shop Blower from Checker.
Old Feb 17, 2005 | 10:01 AM
Strife350z's Avatar
Strife350z
does the water blade scratch the paint?
I would think so considering you're running hard rubber directly over the surface... if you're not careful, wouldn't one loose rock would end up getting dragged across the entire panel?
Old Feb 18, 2005 | 06:00 AM
NismoGCoupe's Avatar
NismoGCoupe
I have black and something I started doing & work’s really good, after washing and rinsing the car let it sit for about 15 minutes. Get a bucket of HOT water and an absorber, dip the absorber in the hot water squeeze the water out but leave it a little damp and start wiping down the car, You’ll see the water evaporating quick without leaving any water marks or streaks.
The hotter the water the better.
Old Feb 18, 2005 | 12:25 PM
DavesZ#3's Avatar
DavesZ#3
Down here in the south, if you let your car sit for 15 minutes it would be dry and full of water spots.
Old Feb 18, 2005 | 01:10 PM
Art Vandaleigh
I just bought the water blade for the hell of it to try it out. Too bad its 20 degrees out so looks like no car washing for awhile heh. I'll post up a review once i use it.
Old Feb 19, 2005 | 02:36 PM
n8vz's Avatar
n8vz
make sure there are no dirt stuck on the waterblade.. otherwise..it will scratch
sales@czp
Sep 23, 2019 03:30 PM
