Using Zaino without ZFX
Old Jun 30, 2005 | 11:12 AM
zand02max's Avatar
zand02max
Default Using Zaino without ZFX
Its about 75-85F in my garage, nice sunny day, and I want to apply Z-2 without ZFX. How long do you let it sit for? I really don't want to leave it overnight. 3-4 hours?
Old Jun 30, 2005 | 12:13 PM
Kevin Overall's Avatar
Kevin Overall
All my coats only take 10 to 15 to dry whether I used ZFX or not and this is in any weather, any time of the year, thin is key...............
Old Jun 30, 2005 | 12:50 PM
disturbed2483's Avatar
disturbed2483
ive been using zaino without zfx here in sunny so. cal and it only takes about 10 min to dry between quotes. as mentioned above thin coats is the key.
Old Jun 30, 2005 | 01:25 PM
zand02max's Avatar
zand02max
Thanks guys, BTW, that Z-PC is the BOMB!
Old Jun 30, 2005 | 08:53 PM
sharingan625's Avatar
sharingan625
how did the z-pc work out? did you use it to remove swirls? i have a black z and swirl is getting worse. im thinking about using z-pc and z-5.
Old Jun 30, 2005 | 09:01 PM
zand02max's Avatar
zand02max
Make sure you use the Z-PC with an orbital. Mine came out awesome.
Paint is cleaner, brighter and most importantly the abundance of swirls are gone,
Old Jul 19, 2005 | 02:18 PM
UCLAzzz's Avatar
UCLAzzz
What happens if you put a thick layer on of zaino on? Does it take longer to cure? I use about 1/2 oz to do my enitre Z and always have a little bit extra at the end. I just go over some areas that I may have missed! It's hard to tell where you've applied the Zaino when you put a really thin layer. Need some advice from the experts here! Thanks
Old Jul 20, 2005 | 10:06 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Kevin is about the most knowledgeable person here when it comes to Zaino but in speaking to Sal about this many times, he said that it isn't just the "drying" process but the "curing" process that takes the extra time.
Again, I think you are confusing DRYING with CURING. Drying is the evaporation of the liquid portion of the polish as it sits on the paint. In warm weather this takes only 15-30 minutes as you said.
But curing or "bonding" if you will, is a CHEMICAL process that doesn't happen in those 15-30 minutes. It take 8-10 hours from what I have been told. This is the way I do it. Right or wrong, I don't know.
sean2168
Cleaning & Detailing
183
Mar 22, 2003 05:36 PM
MacGuru
Oct 19, 2002 03:04 PM
z461
Oct 6, 2002 07:33 PM
Mikey Likes It
Sep 25, 2002 04:52 AM
