Ack! Bird Sh!t on the Z...
Old Oct 10, 2005 | 01:00 PM
siznimper's Avatar
siznimper
Default Ack! Bird **** on the Z...
I was out of town for a week on biz, and I returned to find 4 spots of **** on my Brickyard Z - so I clean them off, wash her up all shiny, and you can still see where the spots were - rough spots in the paint. Am I F'd? Can this be fixed? It's on the hood dammit.
Old Oct 10, 2005 | 01:08 PM
elms350Z's Avatar
elms350Z
Sad to hear that, I had the same experience. Mine was baked under the sun for an hour after cleaning it. Unfortunately, there is nothing you can do about it to my knowledge except wax it. Most cases only you will notice it, and usually that's all it takes to irritate an owner. Good luck.
Old Oct 10, 2005 | 02:59 PM
zredline's Avatar
zredline
I found on another web site to use distilled vinegar on a cloth and rub a little bit then clean with plain water on a cloth should work and repeat if nessary. FYI the vinegar will remove any wax on the area so you will need to re-apply a coat.
Old Oct 10, 2005 | 03:02 PM
DavesZ#3's Avatar
DavesZ#3
Once you get it cleaned off, if you feel a rough spot, that usually means that it's eaten into the clearcoat. If it's a very shallow spot, you might be able to polish it out with a fine compound. If not, it may require wet-sanding or worse.
The best instructions I've seen for fixing "bird bombs" is in David Bynon's eBook "Autopia Guide to Detailing". Sign up at http://Autopia.org and go to the page:
http://www.guidetodetailing.com/arti...p?articleId=58
and download the eBook. Look in the Paint Clinic chapter for "Bird Bombs".
Old Oct 10, 2005 | 10:12 PM
sharingan625's Avatar
sharingan625
ya.
if it went through the clearcoat, vinegar won't do anything.
i've successfully got rid of those marks by using 3m fine cut polish and 3m swirl mark remover.
i pretty much took a little bit of clear coat off to get rid of the mark.
other abrisives will work fine too. just get something to get rid of the haze after the polish. (3m SMR in my case)
good luck.
Old Oct 15, 2005 | 07:13 AM
RA11325's Avatar
RA11325
So happy i found this thread, i had a seagull leave me a present at school the other day.
Old Oct 15, 2005 | 08:01 AM
cracka350z's Avatar
cracka350z
i had like 15 after parking under a lamp at the mall...how gay is that
Old Oct 15, 2005 | 01:57 PM
GreenEnvy's Avatar
GreenEnvy
It's so annoying! Argh. One day after I washed and shammy'd it, a bird pooped right on the hood. I also get sick of all the squashed bugs in the front after I drive 30 miles to work.
Old Oct 15, 2005 | 02:07 PM
cracka350z's Avatar
cracka350z
they are called stickers!! they help you go faster
Old Oct 15, 2005 | 04:19 PM
DavesZ#3's Avatar
DavesZ#3
That's why it's important to keep a good paint protectant like Zaino on your car. I've taken it on road trips and left it sit overnight and washed it the next morning and the dead bugs just slide right off.
HoneyBadgerRy
Sep 21, 2015 03:25 PM
DetailingDude
Cleaning & Detailing
Apr 13, 2003 06:38 PM
Shift_Speed
Jan 30, 2003 07:40 PM
350zpower
Oct 5, 2002 08:25 PM
